September 22, 2026, 08:12:18 am
| | |-+  CSP Bellcrank with mag?
Author Topic: CSP Bellcrank with mag?  (Read 9851 times)
AntLockyer
« on: April 15, 2012, 10:03:19 am »
The throttle linkage I have on my motor is no longer any good as it runs right through where the generator is (never had cooling before). I like the look of the CSP one http://www.csp-shop.com/products/Products/Engine%2CCarburator_Linkages%2CBellcrank_Linkages/20393b/det/ but as I'm running a mag I'm not sure if there will be clearance issues. Anyone run this combo? Any problems? any suggestions of alternatives?
12.618 @ 104.87mph
Fasterbrit
« Reply #1 on: April 15, 2012, 10:12:12 am »
I have fitted this linkage to Ian's Ghia with Idas and there were clearance issues. For
Example, an Msd dizzy wouldn't fit as it fouled the left hand linkage rod. An Msd dizzy is way slimmer than a mag, so reckon
It's a no.
In the end I fitted a vintage Mallory  Wink... It cleared by just a few mm
www.air-kraft.com
www.marcomansiperformance.com
AntLockyer
« Reply #2 on: April 15, 2012, 10:23:01 am »
Ah bugger, thanks Matt. I don't fancy a Berg one because I'll be running aftermarket tin ware so getting it to work right will be a pain.
12.618 @ 104.87mph
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #3 on: April 15, 2012, 14:17:08 pm »
Mine fits with MSD.  but if the mag is any bigger than MSD I'd say it's a no.
« Reply #4 on: April 15, 2012, 14:48:19 pm »
This topic has come up before, I believe.
Here's mine ... no problems. Wink
TxT
JS
« Reply #5 on: April 15, 2012, 14:50:00 pm »
I also run a mag and CSP linkage. It works - barely.
A slight problem on my engine is the tilt of the center piece is limited because on half throttle it hits one of the lower bolts for the fan assembly on the fan housing.
If iŽd used an original in stead of a repro 30hp housing it would probably not be an issue because of different placement of the bolts.
Signature.
Fasterbrit
« Reply #6 on: April 15, 2012, 20:02:54 pm »
Good point Johnny. I also had issues with the linkage fouling the bottom left hand bolt on the fan tinware. I had to use a csk screw if I remember rightly...
www.air-kraft.com
« Reply #7 on: April 16, 2012, 07:53:28 am »
With "reversed" intakes (fuel intake on the outside) and truly horizontal link arms (short intakes) mine worked flawlessly even with the magneto.
henk
« Reply #8 on: April 16, 2012, 11:51:10 am »
i really wanted one of these as well.
and i contacted Gunther of CSP and he said it would not work on my engine with high intakes and MSD distibutor.
henk!!!
Deanodynosaurs
« Reply #9 on: April 18, 2012, 10:25:48 am »
Hi Ant,
Hows things fella. Smiley
I tried to run a genuine DDS twist linkage with a MSD dizzy on mine (not sure how close the DDS twist is to the CSP?) and it didnt work. Left side rod caught the side of the dizzy. I was persistant, and even tried making a plate to move the piviot point back. Although it cleared the dizzy then, it didnt operate very smoothly due to being closer to the fan housing.
So in short, its another no from me.
Dude  Cool
Matty c
« Reply #10 on: April 18, 2012, 14:52:06 pm »
I just finished trial fitting mine yesterday & it works fine! I also run a mag but I have just switched to short manifolds so that probably helps. I also have clearance to the fan housing bolt that has been mentioned. Just for the record it's a scat 30 horse shroud.
Matt
67heaven
Matty c
« Reply #11 on: April 18, 2012, 17:27:16 pm »
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
here you go ant.
matt
67heaven
AntLockyer
« Reply #12 on: April 18, 2012, 21:57:51 pm »
So it looks like short manifolds just work but everything else is out. Thanks guys, will need to just run a CSP Tayco style I guess.
12.618 @ 104.87mph
JS
« Reply #13 on: April 18, 2012, 22:19:08 pm »
No, it can work with long manifolds also as stated above. Just not a lot of clearance.  Smiley
Signature.
AntLockyer
« Reply #14 on: April 18, 2012, 22:26:20 pm »
Your description didn't make it sound like a route I'd want to go down Smiley
12.618 @ 104.87mph
« Reply #15 on: April 18, 2012, 23:47:51 pm »
Ant is this with the superflo heads? if so arent the manifolds "short"  Certainly my Comp elim manifolds were
cheers richie
AntLockyer
« Reply #16 on: April 19, 2012, 09:21:58 am »
cheers richie
Richie thanks, I am an idiot and just assumed they were long for some reason.
Less than 6 inches from head to carb in a straight line. Short ones right?
12.618 @ 104.87mph
Jason Foster
« Reply #17 on: April 23, 2012, 07:06:56 am »
henk!!!
Here is a shot of mine tall CB manifolds MSD and CSP living happily together.
