September 02, 2026, 00:43:06 am
| | |-+  Trouble fitting stacks?
Author Topic: Trouble fitting stacks?  (Read 12949 times)
Jared
« on: April 15, 2012, 21:26:53 pm »
So I'm trying to fit my first pair of Ida's and I would like to run some larger stacks from Jaycee or other companies. I can not get they to fit under the deck lid  to save my life. I put the stock ida stacks on and still won't clear real well. Just wondering if someone has any input on this and maybe has some photos to share?
« Reply #1 on: April 15, 2012, 22:07:32 pm »
Jared,
Yep, unless you're going to run short manifolds, decklid stand-offs or a lower latch extension to partially open it, most all of us will have problems with clearance for the IDA stacks ... especially the larger billet ones!
Outside of those methods mentioned you'd have to cut the interfering stack for clearance.
Don't know another way around it, sorry to say.
TxT
Cheesepanzer
« Reply #2 on: April 15, 2012, 22:36:31 pm »
Even running stock stacks on some cars with wider engines you may need to clearence the stack slightly or run an open decklid.
Just the price we pay to run bitchin carbs!   Cool
 Grin
63 Type 2 Single Cab
Cornpanzers
Hotrodvw
« Reply #3 on: April 16, 2012, 05:25:51 am »
I'm not sure what to expect on a motor close to stock width, runnign IDA's in a '67 sedan.  Ideas?
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
« Reply #4 on: April 16, 2012, 05:32:20 am »
Depends on manifolds. Width isn't as big of a factor as manifold design and height.
« Reply #5 on: April 16, 2012, 05:34:24 am »
My 2165 is about 1/8" narrower than a 1600 and my #2 stack still hits the decklid with Scat Traks.
Hotrodvw
« Reply #6 on: April 16, 2012, 05:45:38 am »
My manifolds are the tall Empi manifolds.
Hose & Fittings
'67 Sunroof
« Reply #7 on: April 16, 2012, 05:47:04 am »
They only fit under the deck lid with short manifolds like mine :-)
« Reply #8 on: April 16, 2012, 06:04:08 am »
I used tall Bugpack manifolds on Asshull's 1915, the runners are not symmetrical so it gives more clearance for the #2 stack. Fits with the decklid closed. Symmetrical manifolds may be better for performance, but if they are not short, the carbs will not fit under the stock closed lid.
Jared
« Reply #9 on: April 18, 2012, 20:03:31 pm »
Thanks for the ideas guys. I'll have to do some more research.
« Reply #10 on: April 18, 2012, 20:49:33 pm »
I prefer to open the decklid because it really blocks the flow for stacks on cil 2 & 4.
« Reply #11 on: April 19, 2012, 01:08:31 am »
I had to cut the stack on the right side to clear the decklid.
'67 with a 1776 (90.5x69)
Hotrodvw
« Reply #12 on: April 19, 2012, 03:31:45 am »
Have any idea on how much you had to cut?
Hose & Fittings
'67 Sunroof
« Reply #13 on: April 19, 2012, 06:43:41 am »
I want to say it was about 3/8" to 1/4" so that's what about 9-7mm.
The way I did is I took a cut with a dremel cut off wheel and then I started to close the decklid and stopped when I felt it touch. After I got it clear, I used silly putty (Think Pla-Doh or modeling clay) until I had the clearance I needed.
Jared
« Reply #14 on: April 21, 2012, 00:21:09 am »
Are there any places that may still sell the bug pack "off set" manifolds still?
bugnut68
« Reply #15 on: April 21, 2012, 00:28:40 am »
I would think, by appearances at least, and I may all wet (Grin), that you would want the decklid offset to allow for more air flow with the larger stacks?  Am I dead wrong in my thinking?
Kaferdog
« Reply #16 on: April 21, 2012, 08:59:42 am »
Wow...Thats funny...Mine fit with no problems at all on my 67.....!!!...I'm running old style CB's talls with IDA's on my 2275 and clear just fine.....!!!
RichardinNZ
« Reply #17 on: April 21, 2012, 10:06:11 am »
I thought I'd post a picture of a famous car to illustrate the issue...
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Hotrodvw
« Reply #18 on: April 21, 2012, 15:45:08 pm »
My new motor I just put together is about 13mm narrower than it was before.  I'm thinking this will only help my fitment.
Hose & Fittings
'67 Sunroof
