July 01, 2026, 20:08:24 pm
bigsiembowski
fuel leaks on terminator 62
Topic: fuel leaks on terminator 62 (Read 3841 times)
bedjo78
April 17, 2012, 13:14:32 pm »
The Terminator 62 has been sitting on self for year. when i installed on newbuilt engine. found fuel leaks from arround trottlle shaft in between carb barrel and accelator pump plunger/cam. I dismantled and clecked but i can find where the leaks from. is there any plunger o-ring or any diaphragm that may worn?
Chris bugster
Re: fuel leaks on terminator 62
April 17, 2012, 15:52:09 pm »
I don't have 62s, but Berg 58IDAs and had lots of problems with them leaking around the plunger and had to machine a bush to fit into the plunger hole to cure this leak. A problem with the material being porous.
11.2@124mph
bedjo78
April 18, 2012, 00:12:41 am »
Chris,
thanks. that's i thought
