October 02, 2026, 16:52:27 pm
Karman Sutra
12
13
14
15
Topic: Karman Sutra (Read 447746 times)
Re: Karman Sutra
Reply #360 on:
April 30, 2017, 03:44:32 am »
Update time ---- Some dude came up to me an made me an offer I probably should of refused, but I didn't and I gave him the big engine out of the Ghia..... So I'm thinking it is time for a more of a street loving engine for the car -- So here is the new incarnation -- A 2332 with a bunch of goodies.... Probably not the total top shelf build I should of done but has enough good parts to get it running and sorted out.....
Still fabbing stuff together and trying to get everything to play together nicely......... The engine is 1/2 inch wider and 3/8" longer than a stocker, so everything that I bought trying to save time, had to be modified and took more time than piecing everything together.... Here's where I'm as of this morning and I'm planning a full day of attacking this thing, but I'll probably spend most of it chasing parts/bolts/stuff if you know what I mean....
The purple lines on the blow-thru hat on the EFI is where I'm having interference with the deck lid -- I'm trying to decide whether to cut the hat and reweld it at the purple lines or offset the deck lid higher -- kind of leaning towards opening the deck lid up as it will add a little more air flow to the engine also....
http://selvedgeyard.com/
Re: Karman Sutra
Reply #361 on:
April 30, 2017, 03:47:08 am »
Playing in the garage today -- made the "spacers" to raise the deck lid -- the results --
Clears everything by a 1/2". So I could of made them a little smaller.... Got some 1/2" black pipe and some 8mm fender washers. Welded the washers to the pipe and came out pretty sturdy... Just need to throw some paint on them...
Almost got the intake system all finished. went to weld on the POP-off valve on, then notice/discovered that the flange was Aluminum.... Oh well, good place to finish for the day..... Off to my favorite Mexican food place for dinner....
Re: Karman Sutra
Reply #362 on:
April 30, 2017, 04:18:16 am »
Can I ask please whether you need to use a scavenge pump with the turbo that low?
Draining straight into the sump?
Thanks.
Re: Karman Sutra
Reply #363 on:
May 09, 2017, 02:12:52 am »
For those of you that warned me about using aluminum for fuel lines with a alcohol based fuel -- -- Well,,,, You were more than right
My injectors looked the same too!!!!!!
Re: Karman Sutra
Reply #364 on:
May 13, 2017, 05:14:45 am »
Fuel system completely redone -- just missing two -8an to -6an fittings -- ordered them from Jeg's today........ Redid the front mounting of the fuel pump and ran the 5/8" lines down through the tunnel -- need to take a picture of that
Oil system is next .....
Re: Karman Sutra
Reply #365 on:
May 13, 2017, 05:22:27 am »
Quote from: modnrod on April 30, 2017, 04:18:16 am
Thanks.
Sorry -- missed your question until just now -- What I've done in the past is just make sure the turbo is higher than the oil level in the engine and then drain line is ran into the sump and I've had no issues so far.... The thinking is as long as the oil has a way to drain even if it is only a short distance, it is still draining..... The whole drain line can have oil in it but as long as there is a gap below the center section your good....
Re: Karman Sutra
Reply #366 on:
May 13, 2017, 05:45:21 am »
Thanks man.
Joel Mohr
Re: Karman Sutra
Reply #367 on:
May 13, 2017, 16:39:15 pm »
The turbo kit I sell is lower than his, and we have no issues. As long as the centerline of the turbo is even a half inch above the oil level, it's been no problem...
SEE YA AT THE RACES!!!
Re: Karman Sutra
Reply #368 on:
May 15, 2017, 04:20:46 am »
[/quote]
slowlearner
Re: Karman Sutra
Reply #369 on:
May 24, 2017, 00:03:01 am »
Quote from: Joel Mohr on May 13, 2017, 16:39:15 pm
...and the oil drain is pointing straight down. Don't ask me how I know this.
BTW, how do you make sure Cyl 1-2 are not leaning out with this setup?
dj
Re: Karman Sutra
Reply #370 on:
May 27, 2017, 04:48:37 am »
Quote from: Fiatdude on May 09, 2017, 02:12:52 am
Is that a compression fitting, I thought your lines was flared
Re: Karman Sutra
Reply #371 on:
May 30, 2017, 01:10:37 am »
compression, not flared
Re: Karman Sutra
Reply #372 on:
July 09, 2017, 20:18:39 pm »
Wow ---------- All my pictures are on Photobucket and now they are being held ransom unless I start paying a monthly fee so that they can be shared ---- this sucks for all my threads
https://www.youtube.com/watch?v=dvjerwo5Vkc
Last Edit: July 09, 2017, 20:27:12 pm by Fiatdude
Re: Karman Sutra
Reply #373 on:
August 04, 2017, 23:54:28 pm »
https://www.youtube.com/watch?v=DYuTGJ_-9UQ
Re: Karman Sutra
Reply #374 on:
August 05, 2017, 02:06:29 am »
That sounds great! Nice little angry lope, very nice.
My PB pics went too, thieves and scoundrels.
Re: Karman Sutra
Reply #375 on:
August 05, 2017, 04:17:02 am »
https://www.youtube.com/watch?v=hp0No45Lz-Q
Re: Karman Sutra
Reply #376 on:
August 05, 2017, 07:31:01 am »
Still dig those telephone dials they look good on your ghia.
Had a set under my beetle but changed it..
Re: Karman Sutra
Reply #377 on:
August 05, 2017, 17:57:39 pm »
thank you -- -- I've thought they were perfect from the first moment I put them on -- -- I can't imagine what I would change them to.
Re: Karman Sutra
Reply #378 on:
August 05, 2017, 22:29:49 pm »
Agreed. I think they look terrible on pretty much every car I've ever seen them on, including the Porsches they came standard on, but this Ghia and one beige bay window bus are the only two vehicles that I've liked them on - in fact both look superb on them!
Re: Karman Sutra
Reply #379 on:
August 06, 2017, 20:43:00 pm »
Thank you Sir
Jeff68
Re: Karman Sutra
Reply #380 on:
August 07, 2017, 13:59:56 pm »
Congrats! Engine sounds fantastic! Hope it runs as well as it sounds!
Re: Karman Sutra
Reply #381 on:
August 08, 2017, 00:10:48 am »
10 pounds of boost will make anything run good LOL
Rocket Ron
It's old school for a reason
Re: Karman Sutra
Reply #382 on:
August 09, 2017, 22:25:08 pm »
You sure have some hours in this, pitty you've lost the photos
Keep up the good work
13.12 @ 101.84
Grooving out on life
Re: Karman Sutra
Reply #383 on:
August 12, 2017, 23:17:33 pm »
https://www.facebook.com/carscoffeecorona/photos/pcb.2009072942671989/2009072846005332/?type=3&theater
Re: Karman Sutra
Reply #384 on:
August 13, 2017, 02:52:43 am »
Haha! Who would have thought a Hilux diesel with red velour would EVER be cool!
Re: Karman Sutra
Reply #385 on:
August 14, 2017, 01:05:00 am »
Went to the Pomona Swap meet today.... ((Bet you guys can tell the wife is out of town for a week))
Wow, I haven't been to one in over 20 years and this thing was massive. Easy 200 VW's in the VW corral. Got a wild hair and hung a For Sale sign on the Ghia for $20K as the guy in the Porsche powered Bus next to me had a price of $100K on it..... But the side panels on it were soooooo straight, I could of taken a picture of my Ghia off it (or you can see my car in the reflection off the door)..... The Double cab behind me was gorgeous too!!!!
No one wanted a HotRod Ghia LOL........
Re: Karman Sutra
Reply #386 on:
August 14, 2017, 01:26:06 am »
Here is a picture of the engine -- finished -- for now -- this week -- today
Have made some templates to cover all the openings around the engine, but need to get some sheet metal to finish.... I've got some stainless sheet laying around but other than my 4" grinder, I really don't have a way of cutting it.
Re: Karman Sutra
Reply #387 on:
August 20, 2017, 17:29:39 pm »
Get a plasma cutter Harold, with a little practice you can cut virtually millimetre perfect. If you can draw freehand with a marker pen, you can use a plasma!
Re: Karman Sutra
Reply #388 on:
August 20, 2017, 20:26:17 pm »
Then I'd have to get an air compressor large enough to support it -- -- planning to move, maybe, in the next six months, so large/heavy item purchases are on hold.
Didn't take any pictures or videos as I went by myself, but I went out to California Speedway for some AutoX. The event was held by Fastivus. Did some laps. My 5-6 year old tires were really holding me back.... The rear end was sliding out from under me the whole time and when it wasn't, the front end was pushing......
Had the speed up for a tight section and was trying to whip the rear around to setup for the next section .. .. .. Ended up doing this really slow looping slide right through this huge area of cones..... Did win the unofficial award for most cones collected (knocked down) for the day LOL
Noticed the Ghia wasn't pulling as hard as 'normal' -- found the seal between the hat and the carb had squirted out -- need to find a fix for that.....
Re: Karman Sutra
Reply #389 on:
September 14, 2017, 19:35:26 pm »
Here's the fitting I use Martin
12
13
14
15
