October 14, 2026, 14:33:20 pm
| | |-+  Fuchs on late model
Author Topic: Fuchs on late model  (Read 13032 times)
volksnut
« on: April 23, 2012, 01:26:50 am »
Thinking of changing the Amercian's out for a set of either Fuchs (Porsche pattern no adapters) or maybe some Erco type wheel (either 4 lug or Porsche pattern). My car is a 72 standard with IRS....anyone with size/offset fitting ideas, rear tires will be the M@H 215/65-15's, and I have a 2" narrowed beam
« Reply #1 on: April 23, 2012, 02:06:18 am »
I think your current wheels make your car really stand out, so don't change them!
But if you must... I think Erco's (or similar wheels) only look right in wide 5. A 6" Porsche wheel works great on a 2" beam with drop spindles, use a 175/65 or 185/60 tire. 6" Porsche wheels will work in the rear also. 7" needs narrowed trailing arms to fit in the fender.
Why not put the M&H's on the Americans?
volksnut
« Reply #2 on: April 23, 2012, 02:56:59 am »
Yeah I kinda always thought that, and yeah I could just put them on those wheels...and spend the $ on something else
« Reply #3 on: April 23, 2012, 03:41:52 am »
Late 6s & 7s with 185/60-15s front, 215/60-15s rear.
Trailing arms are narrowed to offset rear discs.
 Wink
TxT
pupjoint
« Reply #4 on: April 23, 2012, 05:49:41 am »
 Wink
TxT
TexasTom, you running a stock beam or narrowed? dropped spindles , stock disc brakes?
« Reply #5 on: April 23, 2012, 06:22:26 am »
Say Tom, what disk set-up do you have out back?
Ted
Gaz1
« Reply #6 on: April 23, 2012, 08:13:13 am »
This is my old 68,Porsche pattern with no adapters...
Flow
« Reply #7 on: April 23, 2012, 08:48:20 am »
My friend with 5'narrowed beam, drop spindles, discs and 5' fuchs on the front, and 6' on the rear. With 145/15 and 205/70r15  Wink
« Reply #8 on: April 23, 2012, 11:58:31 am »
 Wink
TxT
Running Airkewld's 'Bad Brakes' all the way around with the interchanging hubs. Beam is custom-narrowed 2 1/2" by myself with one adjuster and 2" lowered spindles.
Sorry for leaving that out! Cheesy
TxT
volksnut
« Reply #9 on: April 24, 2012, 02:30:34 am »
Hey Tom, what offset are the rear wheels...can I get a 4 1/2" offset with a total of a 7" wheel in there, mine has drum brakes with stock trailing arm?
« Last Edit: April 24, 2012, 02:32:17 am by volksnut » Logged
« Reply #10 on: April 24, 2012, 06:37:31 am »
Here is my car when I ran Late 6's all around. With 2' CB narrowed beam and CB drop spindles. Running TypeIII brakes out back.
bluestar
D.A.S member
« Reply #11 on: April 24, 2012, 17:58:00 pm »
my 68' with deep6 and T3's brake rear ... 5.5 +disq+dropped spindle front , 205-70-15 and 145-15....
« Reply #12 on: April 24, 2012, 18:34:36 pm »
I'll see what I can do for ya ... maybe this weekend I can pull one off and measure.
TxT
« Reply #13 on: April 24, 2012, 19:10:18 pm »
now we want to see that car with the DEEKS stickers  Roll Eyes......l  Wink
« Reply #14 on: April 24, 2012, 21:19:51 pm »
 Coming very soon Fabs.....I hope. Grin
« Reply #15 on: April 25, 2012, 06:28:24 am »
Late 7" Fuchs have an offset of 23mm.
« Reply #16 on: April 25, 2012, 07:45:43 am »
5.5 and 6" early Fuchs. Stock beam without adjusters, CB drop spindles.
145/15 and 165/15.
« Reply #17 on: April 25, 2012, 13:42:26 pm »
I checked with a friend running 7s with drums and stock arms. With 205-70/15 tires it does rub the sidewalls a little. A 65-series might change things.
« Reply #18 on: May 01, 2012, 06:47:54 am »
You asked, and you shall receive..... Grin   Sorry for the off topic.
« Last Edit: May 01, 2012, 06:52:52 am by DKK Racecraft » Logged
« Reply #19 on: May 01, 2012, 18:14:12 pm »
thx ted and congrats for your deeks admission
« Last Edit: May 06, 2012, 16:06:33 pm by speedwell » Logged
« Reply #20 on: May 06, 2012, 15:23:01 pm »
Ted! I see it only now! Congrats!  Smiley Grin
volksnut
« Reply #21 on: May 07, 2012, 21:08:39 pm »
Well the Amercian's are sold off.....now I wait on jack stands, time to change out some bushings and new wheels...Update coming soon
