November 04, 2026, 07:20:27 am
| | |-+  Deutz liners and piano wire mod.
Author Topic: Deutz liners and piano wire mod.  (Read 5614 times)
Bad bug
« on: April 29, 2012, 20:37:49 pm »
Hi All,
I am building on paper a 2.7ltr t4 engine with deutz liners to be used as a daily driver has anyone done the piano wire mod to a t4 head and deutz liner before.
Fasterbrit
« Reply #1 on: April 30, 2012, 07:26:08 am »
I am very intrigued to know more about this piano wire mod. Do you know what's involved? Cheers
www.air-kraft.com
www.marcomansiperformance.com
m.m.p
« Reply #2 on: April 30, 2012, 08:09:07 am »
Its done on highly stressed watercooled engines to give more of a "bite" into the original head gasket,  make a 1mm wide and 0.8-0.9mm deep groove in the middle of the barrel sealing area and use 1mm wire. This makes a high point for the wire to bed itself in to the metal gasket ring.
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
« Reply #3 on: April 30, 2012, 09:45:56 am »
Why couldn't you just turn down the cylinder to make the same effect? You could actually make it "sharp" too.
Bad bug
« Reply #4 on: April 30, 2012, 10:16:53 am »
Ok so i would have to use copper head gaskets then, no problem.
Bad bug
« Reply #5 on: April 30, 2012, 10:18:29 am »
Well if this idea was used i would have to do a lot of machining since the Deutz liners are way hard. I think i would want to try the piano wire route.
Bad bug
« Reply #6 on: April 30, 2012, 10:20:33 am »
Hey how is the waterboxer doing, haven't heard anything about it since you made a couple of runs at santa pod. By the way can this car be street driven.
