September 23, 2026, 09:19:51 am
| |-+  For sale!
| | |-+  Mex 1600i intake system - reserved -
Author Topic: Mex 1600i intake system - reserved -  (Read 2503 times)
Airspeed
« on: May 02, 2012, 10:14:48 am »
For sale: complete 1600i intake manifold EFI 'kit'. Ideal to be starting injection as you'll have most of the hardware complete at once:
- 2 intake elbows with new Samco hose connections and custom made suitable for all modern 14mm injectors. Injector space is for the smaller (pico) injectors atm, but can easily be modifies to take the more common longer injectors as well. Offering is without the injectors in the pictures.
- central T-piece manifold,
 - throttle body,
- air temperature sensor,
 - Throttle position sensor,
 - fuel pressure regulator (don't know if its working properly, but should be, its adjustable though),
 - custom fuel rails,
 - 4 alu dash-06 connections in the fuel rail,
 - new generator pedastal suited for these double intake runners, complete with new bracket and cap.
Intake elbows are ported for better flow  8-) .
- reserved -
Thanks for looking,
Walter
« Last Edit: May 05, 2012, 20:06:40 pm by Airspeed » Logged
