October 13, 2026, 21:55:31 pm
| | |-+  Mid mount
Author Topic: Mid mount  (Read 5503 times)
« on: May 03, 2012, 11:00:08 am »
Has anyone got any experience fitting a mid mount like this one?
As I understand the rubbers need to compress in order to install the mid mount, but my attempts so far have been in vain.
I figured I'd ask around  Grin
« Last Edit: May 03, 2012, 11:01:50 am by 67-indeed/DVK » Logged
tikimadness
« Reply #1 on: May 03, 2012, 11:58:16 am »
I would weld one in!!
Michael
NIDGAFWYT
« Reply #2 on: May 03, 2012, 14:57:13 pm »
I wouldn't. Rule of thumb is all solid or all rubber and I ain't going with solid mounts, hence I wanna use what I already have.  Smiley
« Reply #3 on: May 03, 2012, 15:10:25 pm »
Perhaps if you put a jack under the engine/transmission and take out the two bolts that secure the transmission cradle to the frame horns the lower the jack a little and install the mount on the transmission and put the rubber mounts in place then jack the engine/transmission back up and install the bolts.  I would think that would work.  You will need a long 27mm box end wrench in order to break it loose and get it tight again.
« Reply #4 on: May 03, 2012, 15:46:40 pm »
Good idea, Donny!
 Wink
TxT
« Reply #5 on: May 03, 2012, 16:36:20 pm »
Thanks Don, that makes sense! I'll see how that works out (once I get to work on my car again).
Just one question, won't that put the front mount (front rubber) under a lot of stress?
Hotrodvw
« Reply #6 on: May 04, 2012, 06:43:12 am »
I run a stock nose cone mount, a mid mount like you have there, and a solid rear mount.  I installed my mid mount on the trans with it out of the car.  Doing it in the car may require a jack like suggested.  My solid rear mount is great......no issues.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
ibg
« Reply #7 on: May 04, 2012, 07:24:48 am »
Cos frame horns vary a bit you need to trim the urathane untill it is a firm fit but not forced or yes, you will tear the front mount. Guess how i found that out Undecided
