September 22, 2026, 22:18:02 pm
| | |-+  Mahle part number question
Author Topic: Mahle part number question  (Read 6842 times)
wolfswest
« on: May 11, 2012, 22:19:40 pm »
Hi,
I'm trying to find out what kind of piston set I have.  I hope/supose that mahle uses for every model of piston a different part number, right?
Part number is 92p17, it is 100% a 94...  i guess a piston for original stroke has a different part number then a model for a stroker crank?  Can I be sure if I find a set with the same number that it is a match?
Thx,
« Reply #1 on: May 11, 2012, 23:53:20 pm »
hello dem,
i have the 31's  Sad
but i have a set of 4
cheers, Peter
volkskris
« Reply #2 on: May 12, 2012, 11:19:13 am »
http://mahle-aftermarket.com/C1256F7900537A47/vwContentByKey/W282DNFX142STULEN/$FILE/Catalogo-MH-2011-2012-Pistoes-web-01.pdf
check page 204. 92p17 corresponds with 92mm pistons for 69mm stroke. if it's a 94 bore 94p17 is the number for 94mm pistons with 69mm stroke I think.
You guys need to learn how to use google  Grin
wolfswest
« Reply #3 on: May 12, 2012, 12:13:52 pm »
so the pdf is wrong!  Grin  my pistons are 100000% 94mm's and the partnumber is 92p17...
volkskris
« Reply #4 on: May 12, 2012, 13:27:10 pm »
there is something wrong but where? naming 94mm pistons 92 would be a bit wierd Tongue
