September 14, 2026, 08:03:22 am
Bad Habit
zero offset dropped spindles
Topic: zero offset dropped spindles (Read 20509 times)
CHR!S/DVK
May 14, 2012, 16:30:24 pm »
i am planning to install vw disc brakes on the front of my 69 beetle. at this moment i am running dropped spindles on a 2.9" narrowed beam with spacers.
do zero offset dropped spindles exist? the cb performance website tells that theirs give 1/4" offset, and a set of Mid American Motorworks that i can buy has the same.
i did a quick search here and read that cb intended to make zero offset sets, but apparently they didn't.
is it possible to narrow a beam with 1/2" total? and do disc brakes give the same total width as drums?
Member of
DVK
- Der Vollgas Kreuzers
CHR!S/DVK
Re: zero offset dropped spindles
May 18, 2012, 19:41:22 pm »
Quote from: CHR!S/DVK on May 14, 2012, 16:30:24 pm
any knowledge or advice around here..?
Member of
DVK
bugnut68
May 18, 2012, 21:47:03 pm »
Seems I remember there was, indeed, a set of zero-offset drop spindles available... EMPI perhaps? I don't recall who made them, but I know I recall seeing them out there.
bugnut68
May 18, 2012, 21:48:58 pm »
My biggest beef with the CB spindles, and there's was absolutely NO warning at the time I bought them, is I'm VERY limited as to which rims I can run on my car with a stock-width beam. Shy of redoing my entire front suspension, I'm stuck running either Empi 8's or stock steel or chromie rims. Had issues with the inside bottom of a wheel hitting my bottom balljoints when I tried to run genuine 2.0 liter Porsche 914 alloys.
volkskris
May 18, 2012, 23:40:09 pm »
Bugnut do you know the max et-size or offset on a 5.5x15 rim while using a stock beam and cb dropped spindels?
bugnut68
May 19, 2012, 01:35:14 am »
Quote from: volkskris on May 18, 2012, 23:40:09 pm
That I don't know... all I do know is I ran Empi-style 8-spokes, which I believe are 5.5x15 inch rims, with my stock beam/CB spindle set up. I had to space the rim out to clear the disc brake caliper, but aside from that, no issues.
May 19, 2012, 01:53:23 am »
Grind the ball joint, clearance the caliper, no big deal!
bugnut68
May 19, 2012, 02:28:59 am »
Quote from: Zach Gomulka on May 19, 2012, 01:53:23 am
The wheels are long since sold, but the advice that wasn't available at the time I was asking was that I had the option of having the inside hub area machined so they'd fit in a little closer and thereby giving me clearance. Lesson learned, though I don't know why nobody had this suggestion until after the wheels were gone! lol
thehanz DVK
May 19, 2012, 16:54:16 pm »
You say you use spacers....how big are they ?? you can already loose the spacers or not ?
CHR!S/DVK
May 19, 2012, 18:17:57 pm »
Quote from: thehanz on May 19, 2012, 16:54:16 pm
i think my spacers now are 2cm thick, but i am already running dropped spindles that give a offset..
thanks for the replies, all other ideas are welcome. i'm going to think about your comment zach!
Member of
DVK
May 19, 2012, 21:59:10 pm »
Quote from: CHR!S/DVK on May 19, 2012, 18:17:57 pm
It's really no big deal. I had to grind the caliper a little bit to clear the Sprintstars on my GTV, and I had to grind the ball joint a hair on AssHull's '67.
The advantages of drop spindles far outweigh the disadvantages.
CHR!S/DVK
May 20, 2012, 21:20:27 pm »
Quote from: Zach Gomulka on May 19, 2012, 21:59:10 pm
that's good news! i don't know much about front beams, but if you're sure that it will work on my 69 beetle..
i heard that slightly narrowing a beam is easy on 66(or something) and earlier, but that it's more difficult on later beams.
Member of
DVK
May 21, 2012, 05:54:17 am »
What wheels and brakes are you going to use?
May 21, 2012, 10:49:21 am »
Just run normal dropped spindles. Your beam is already way to narrow
CHR!S/DVK
May 21, 2012, 11:03:55 am »
Quote from: Zach Gomulka on May 21, 2012, 05:54:17 am
i'm going to run vw discs and 914 mahle wheels:
Quote from: Jesse/DVK on May 21, 2012, 10:49:21 am
i want to lose my narrow beam and come as close as possible to stock width with discs on front (without spacers)!
so that means a "new" front beam
Member of
DVK
CHR!S/DVK
May 21, 2012, 11:09:24 am »
Member of
DVK
May 22, 2012, 04:56:27 am »
You *might* get away with a stock beam and drop spindles if your Mahle's are wrapped with skinny and/or short tires, and you have very little body roll (sway bars).
If it was my car, I'd run a 2" beam with drop spindles and something like a 175/65 on those Mahle's.
