August 12, 2026, 21:58:39 pm
352259 Posts in 28945 Topics by 6923 Members
Latest Member: Lotus67
| | |-+  Size on oil sump with dry sump system ?
Author Topic: Size on oil sump with dry sump system ?  (Read 6796 times)
SMO
Typ 1 -61
« on: May 15, 2012, 22:29:47 pm »
what you think about the Size on oil sump when you have
Dry sump , i have 4 qt and a 1 1/2 qt
I think i Will use the smaller one, what do you think ?
And what do you use
// magnus
« Last Edit: May 15, 2012, 22:31:49 pm by SMO » Logged
« Reply #1 on: May 15, 2012, 22:31:56 pm »
If you are doing dry sump set up you dont need any extra sump on the engine
cheers richie
« Reply #2 on: May 16, 2012, 18:34:53 pm »
Never bolt on an extra sump on a drysump engine. Perhaps a small 20 mm that we use for smaller street engines .
andy198712
« Reply #3 on: May 16, 2012, 22:48:12 pm »
What pumps are people using on street builds?
The idea of dry sump is that A your sump isnt filled with oil aka dry and B the "sump" is the oil tank Wink
« Reply #4 on: May 17, 2012, 06:06:09 am »
I am going with the salzburg pump.
« Reply #5 on: May 17, 2012, 07:54:07 am »
CB's in and out pump seems really good for the street,
cheers richie
SMO
Typ 1 -61
« Reply #6 on: May 17, 2012, 14:12:02 pm »
Okey , so no sump is the thing.
I Will use cb dry sump and tank.
owdlvr
« Reply #7 on: May 18, 2012, 00:12:31 am »
I've got the CB tank in my setup, and I'd say it's worth paying twice as much for a Peterson (or similar) tank. The Money savings in the CB tank comes from the fact that you can't split the halves like in more expensive tanks...which means you can't clean the tank out. I didn't think this was a big deal until I filled my oil with metal particles from an engine failure.
The grief of cleaning out the tank, and the wish that I could clean my tank every oil change, means I'm going to be upgrading to a Peterson tank soon.
-Dave
« Reply #8 on: May 18, 2012, 03:44:40 am »
Be careful in choosing the CB tank if it is not a very simple streetcar with almost no G forces.
Too small tank (Wide and no height), no baffles, no dearator function and as mentioned in previous post, no posibility to open up.
I bought and modified it slightly but ended up reverting to my older byt higher larger tank from Pegasus.
A nice and what I think is British built tank.
Petersen, Moroso, Aviaid and more make nice tanks but of course at a different price.
« Reply #9 on: May 18, 2012, 05:29:52 am »
I use a tank from a company made in germany and make my own pumps. 26 mm out and 38mm in
