September 22, 2026, 11:52:20 am
| | |-+  Standard oil cooler and dry sump ?
Author Topic: Standard oil cooler and dry sump ?  (Read 4017 times)
SMO
Typ 1 -61
« on: May 18, 2012, 06:50:01 am »
Do you use standard oil cooler when you have
Dry sump ? I have 19 row external oil cooler to.
I see cb has a Block off plate # 1733 use then you have
Dry sump system ?
What do you think ? I have cb sump system.
// magnus
« Reply #1 on: May 18, 2012, 08:08:39 am »
On the CB set up I think they recomend using an external oil cooler & filter in the return line to the dry sump tank,that way you oil pumped to the engine is allways clean and cooled ready,I delete the factory oil cooler
cheers richie
