November 02, 2026, 18:13:12 pm
| | |-+  Clutchsystems
Author Topic: Clutchsystems  (Read 17507 times)
Mirco Jufer
« on: May 22, 2012, 11:43:56 am »
Hey Loungers
I have a Question...
For Dragracing (with hopefully fast Shifting) it is better to use a Operation with hydraulic or with a Wire?
I Use a Stage 3 Pressure Plate.At the moment i use a very old hydraulic system but it works a bit crazy.
For the first 4-6 Runs it works,but at once (mostly on the 2.Raceday or a long time in the Pits) the 2. Gear will not shift.
But only when i will shift very fast,slow it works allways fine.
With the hydraulic, the Brakefluid is fast enough back in the reservoir to close the Clutch complete?
Thanks for helping
dragvw2180
« Reply #1 on: May 22, 2012, 13:03:14 pm »
 On my car I am running a hydralic clutch and RLR REV6 clutch setup. In the last few years I have tried alot of differant setups , from single discs to double . Depending on your clutch setup and  if you have enough travel in you system  it may be the mass of the disc. I do not know what size line you have going to it , but I run 1/4  . If the line is too small it will react slowly both pushing and releasing. Here is the clutch I am running , Mike McCarthy
Mirco Jufer
« Reply #2 on: May 22, 2012, 18:04:16 pm »
Woww that looks fine!
My line is only 1/5 Inch Outer Diameter.
I am not sure but i hope thats not a Problem from the Gearbox himself?
I think when its the Gearbox it make to Scrach when the 2.Gear not want to shift???
This are my Cylinders
Airspeed
« Reply #3 on: May 22, 2012, 20:25:22 pm »
I use a annular slave throw-out bearing and only a brake line as clutch line and works fine and still as fast enough as I can shift.
« Reply #4 on: May 22, 2012, 20:26:56 pm »
Hey Loungers
Thanks for helping
Do you have pro rings ?
Mirco Jufer
« Reply #5 on: May 22, 2012, 22:14:07 pm »
No pro rings,whats that?
« Reply #6 on: May 23, 2012, 05:36:21 am »
prorings for the gears for proshift ,this is what you need first.  We are happy with our cables for the clutch. never used a hydraulic
« Reply #7 on: May 23, 2012, 06:06:27 am »
Isn't there something in this months VW ultra about pro-rings?
jaqo
Bugster Team
« Reply #8 on: May 23, 2012, 10:52:13 am »
Where is this bearing from?
Airspeed
« Reply #9 on: May 23, 2012, 11:45:05 am »
I just used a VW Passat hydraulic TO bearing (made by Lucas iirc) and shortened the in- and outlet some, tapped it for the brake line hose ends and done ;-)
« Reply #10 on: May 23, 2012, 12:33:15 pm »
Brilliant!
Finally a clutch control from the 21st century! Wink
Excellent adaptation ... I like it!
TxT
jaqo
Bugster Team
« Reply #11 on: May 23, 2012, 18:07:55 pm »
Very clever. What kind of passat?Wink
Airspeed
« Reply #12 on: May 23, 2012, 19:46:43 pm »
Thanks Tom! Its very easy on the right foot too  Wink
Joga, I think it was from a 3BG model 2001-2003, but just compare the model. A lot of other VAG brands (Audi, Skoda etc) use it as well.
I choose this one as its the most low profile one (41mm fully compressed) of all types I looked at.
« Reply #13 on: May 24, 2012, 01:32:30 am »
The application is the same for a 6 speed '03 'Anniversary edition' GTI or say an '08 Passat with standard tranny.
0A5 141 671F
 Wink
« Last Edit: May 25, 2012, 14:20:57 pm by TexasTom » Logged
gbaker770
« Reply #14 on: May 24, 2012, 02:57:05 am »
Very nice!
« Reply #15 on: May 24, 2012, 04:08:21 am »
That is a trans problem with the syncros/shifting fork -- not clutch
« Reply #16 on: May 24, 2012, 05:22:48 am »
I would say Mirko first needs prorings . if you once shift with those you will never have something else
Mirco Jufer
« Reply #17 on: May 24, 2012, 06:45:50 am »
Thanks Udo...but not this Year Sad
With the Engineoverhaulin my Budget for this Year is overused...
I think its too expensive for me.
« Reply #18 on: May 24, 2012, 07:02:30 am »
Proshift kit $329 from Rancho http://www.cal-look.com/pro-shift-kit/
Mirco Jufer
« Reply #19 on: May 24, 2012, 09:57:10 am »
Hey Udo,had Frank with the Little Grey allso Prorings?
jaqo
Bugster Team
« Reply #20 on: May 24, 2012, 11:15:54 am »
I tried both - pro rings in a pro stock beetle and normal synchro in my vw-fiat (shift point at 8200-8400rpm) and I don't see much diffrence - synchro gearbox works very fast, pro ringed one a little bit better but it's not a big diffrence. The fact is that synchromesh are very sensitive to gearbox oil quality and they wear out, pro-rings would probably work even without the oil;) My next gearbox won't have pro rings.
Mirco Jufer
« Reply #21 on: May 24, 2012, 14:35:24 pm »
Hey Jago,what Oil do you recommend ?
Thanks for Info
jaqo
Bugster Team
« Reply #22 on: May 25, 2012, 03:38:29 am »
I have a fresh 80w/90 gearbox oil (polish brand) and it works fine. Maybe your synchro ring is worn?  Or your oil is getting hot. Or both;)
« Reply #23 on: May 25, 2012, 05:33:41 am »
Yes he has , since he had problems with 2. gear
Mirco Jufer
« Reply #24 on: May 26, 2012, 06:02:23 am »
Ok thanks Udo
I think i will Overhaulin the Gearbox evtl. for next Season...but this Season...you know Zwahlen,he is expensive,and he dont drink Beer... :-)...or to less to make a big Deal with him... Wink Wink Wink Wink Wink Wink
