October 13, 2026, 15:27:02 pm
| |-+  For sale!
| | |-+  Turn-key Type 1, 2387cc, 52mm Berg, MSD.
Author Topic: Turn-key Type 1, 2387cc, 52mm Berg, MSD.  (Read 7634 times)
kormi
« on: May 24, 2012, 12:10:53 pm »
2387cc Type 1 motor.
86mm CB crank, wedgemate with Stage II og sinter clutch.
94mm Wiseco pistons.
Welded case with deepsump.
Mahle cyl.
CB044 welded and ported by JPM, Sweden.
JPM/Oteva valvesprings.
52mm Gene Berg carbs with CSP-Bellcrank.
1:4 Pauter rockers.
Manton pushrods.
FK 89 cam.
12.4 compression.
A1 1-3/4" cheramic exhaust with stingerpipe.
Full MSD 6 Digital ignition and distributor with 2-step.
Summit fuelpump + regulator and fuel-lines/AN-fittings from regulator to carbs.
No fan shroud.
Dynoed 234 hk/285 nm on pumpgas (95).
Runs on E85 at the moment.
This is the engine from Jørans Berserk-racer for those who know it. Best ET so far 11,1@1/4mile.
Located in Jessheim/Gardermoen(SCC), Norway.
Can be shipped on your expense.
Will post a few pic this weekend.
EUR 8.000 / NOK 60.000 (any bids?)
http://www.youtube.com/watch?feature=player_embedded&v=y2Mfm6vPF8s
« Last Edit: May 28, 2012, 13:29:56 pm by kormi » Logged
Boost it...
JS
« Reply #1 on: May 25, 2012, 18:44:37 pm »
Having crewed for the BERSERK car for a couple of seasons, I can really vouch for this engine, top parts and workmanship. The heads are a work of art!
The many low 11sec runs in a heavy all steel car also suggests there´s more power in it now tuned on E85 IMHO.
Signature.
kormi
« Reply #2 on: May 28, 2012, 13:29:24 pm »
Thank you for nice words, JS.
Engine is still looking for a new owner.. Here's some cellphone pics.
Boost it...
kormi
« Reply #3 on: May 28, 2012, 13:39:37 pm »
Boost it...
kormi
« Reply #4 on: June 02, 2012, 17:55:27 pm »
Open for bids..
Boost it...
« Reply #5 on: June 02, 2012, 18:41:11 pm »
Hi,
Couple of questions. What head studs are you using and what 'pump' fuel were you using with 12.5:1 compression ratio?
Lee
kormi
« Reply #6 on: June 12, 2012, 15:40:58 pm »
Hi,
headstuds are 8mm chrommoly. Fuel at that time, 95 octane.
Boost it...
kormi
« Reply #7 on: June 18, 2012, 10:59:59 am »
Bump!  Smiley
Boost it...
kormi
« Reply #8 on: June 26, 2012, 13:31:36 pm »
Bump!  Smiley
Boost it...
kormi
« Reply #9 on: July 05, 2012, 09:46:46 am »
Sold
Boost it...
