July 02, 2026, 14:35:15 pm
Latest Member: bigsiembowski
| | |-+  My mag is fighting me
Author Topic: My mag is fighting me  (Read 5451 times)
« on: May 24, 2012, 20:50:29 pm »
hello guys,
yeah, another magneto topic Smiley
i bought a scintilla and wanted to see if it has advance or not...
so..installed it...0,5 mm plug gap, with the cigarette paper i set the advance to about 15°
but it wouldnt start.. advanced a bit... then it started and was running and then died again...
now not possible to start anymore?
is there a trick with these things? the engine should run fire up from 10- 30°, right?
worth to mention is that the engine runs fine with other ignition, so its not carb related
« Reply #1 on: May 25, 2012, 21:50:37 pm »
How much gap do the trigger points have?
TxT
« Reply #2 on: May 25, 2012, 23:44:59 pm »
hello Tom,
fiddled a bit more today and got it running again...
i could check the advance finally, and i need to modify the mag...
the advance goes up to +- 45° when the rpm's go up..
i set it statically at 15°, so i need to find a way  so it advances max to +- 30°
Ole
« Reply #3 on: May 27, 2012, 22:00:47 pm »
45°  advance Shocked Shocked
Then you'd have to start the engine at 15° AFTER TDC...
Or do you get 45 if set to 15 static? If so it's still 30°.
Most "stock" Mags come with 12ish advance.
If it's a race car just lock it, if it's a street car put it to 20-22°.
Ole
no cerveza?
no trabajo!
« Reply #4 on: May 28, 2012, 11:28:48 am »
Haha Ole, i know Smiley
i thought this is a stock one (it came off an industrial engine the seller told me)
maybe my timing light is playing tricks on me ? allthough it works fine with the electronic ignition..
I just revved the engine up to see the advance...No driving with 45° Smiley i also didnt rev higher, so advance might have been even more at 7000?
on the mag it says: 0° at 400 and 12° at 1750 i think... so thats why i set it statically at 15 to get around 28 full out...
but it advances further.... I thought it could be due to the engine running faster than 2000 and pushing the advance weights further than they should be?
or is there a stop somewhere that stops the weights? i tried to open it up, but i dont have the correct tools or knowledge about them, so i couldnt take a look at the weights..these things are made to never take apart!!
cheers, Peter
sam P
« Reply #5 on: May 30, 2012, 23:44:45 pm »
RPM and degrees marked on the magneto are camshaft degrees.
x2 for crankshaft degrees, that makes: 0° at 800rpm, 24° at 3500rpm.
15° initial advance is too much, give it 8° initial, this should give you 32° at 3500rpm. Llisten to your engine when you drive it hard. Wink
« Reply #6 on: June 04, 2012, 14:36:37 pm »
thanks Sam!
I ll try it
