September 22, 2026, 14:38:37 pm
Need picture of after market heads like superflows
Topic: Need picture of after market heads like superflows (Read 7209 times)
May 29, 2012, 17:00:59 pm »
Thinking about makeing some universal type cylinder tin end peices. That would fit like DDS,Jeff denham angle flow, superflow type heads. If you guys could post pictures from different angles and maybe leave ideas that would help you out. I want to start getting ideas like mounting. and useing stock peices to work with the peices I want to make. Keep the fab/labor time down. Thanks for any help!
deano
Re: Need picture of after market heads like superflows
May 29, 2012, 19:17:06 pm »
Danny, Danny, Danny.... Where have you been? Hot VWs pubished two stories last year with EVERY modern day, Type 1 and aftermarket head castings on the planet. Complete with photos....
Anglia Obsolete Guru
'67 Heaven
May 29, 2012, 19:39:31 pm »
I need to get out of the shop more!! I will look for it. I just found out they put a man on the moon.
Speed-Randy
May 29, 2012, 20:53:59 pm »
Quote from: danny gabbard on May 29, 2012, 19:39:31 pm
When did that happen??? Was this on the news?
www.vdubspeedshack.com
May 30, 2012, 00:19:16 am »
Photos SENT!
TxT
p.s. That 'man on the moon' stuff sounds pretty CRAZY! You might want to check into that before speaking about it OUT LOUD, if you know what I mean ...
Last Edit: May 30, 2012, 00:21:08 am by TexasTom
May 30, 2012, 10:08:32 am »
Quote from: TexasTom on May 30, 2012, 00:19:16 am
Photos SENT!
TxT
Thats nothing, did you hear about the Martian invasion in 1898! Tripods, heat rays, red weed, it was hell.
58vw
May 30, 2012, 18:18:00 pm »
here is one...mr jeff is sending you one i beleive
www.4inbore.com
Angleflows...order them now
May 30, 2012, 18:44:10 pm »
May 30, 2012, 20:49:57 pm »
Is that a skatepark or a vw head?
May 30, 2012, 22:57:24 pm »
Both ...
May 30, 2012, 23:00:06 pm »
No kidden! Have any shots with the valve cover and manifold?
AntLockyer
September 26, 2013, 12:52:14 pm »
Did you end up making these?
12.618 @ 104.87mph
