August 13, 2026, 09:49:43 am
| | |-+  fuel pressure regulator
Author Topic: fuel pressure regulator  (Read 9202 times)
goose
« on: May 29, 2012, 19:54:25 pm »
need your help folks
i need a low pressure fuel regulator with a return (bypass) back to the tank
everyone i have talked to so far can't supply one with the return
any help would be appreciated
Angus
2015 the year finally racing
« Reply #1 on: May 29, 2012, 21:23:09 pm »
mallory do a good one,part number 4309 that I have used a few times
stretch
« Reply #2 on: May 30, 2012, 12:12:38 pm »
Sorry for the thread hi-jack, but, can someone suggest a decent quality 2 port reg (low pressure - for IDA's) that doesn't require a return to the tank please?
Cheers.
« Reply #3 on: May 30, 2012, 12:31:50 pm »
Holley?
stretch
« Reply #4 on: May 30, 2012, 12:39:35 pm »
Holley?
Got one of those, not too happy with it.
« Reply #5 on: May 30, 2012, 13:02:47 pm »
Holley?
Mallory 4207 would be good for that Stretch,and I have those ones in stock Wink
stretch
« Reply #6 on: May 30, 2012, 13:52:55 pm »
Richie, they only go to 4psi, won't that by-pass the inlet needle valves on IDA's?  (They are Jaycee 51.5mm with the glass balls replaced with standard brass inlet needle assembly).
« Reply #7 on: May 30, 2012, 14:18:11 pm »
They should be ok,I have used them with the standard needle and seats on road cars and havent had any issues with them bleeding over,with the 3.0 glass ball I am not so sure
you can just see one behind the shroud on this ghia we built the engine for Wink
stretch
« Reply #8 on: May 30, 2012, 14:21:16 pm »
Thanks for that.
I might have to give you a shout after payday.   Wink
Tobi/DFL
« Reply #9 on: May 30, 2012, 14:27:41 pm »
Cheers.
Hi,
I use a Malpassi/Filter King pressure regulator with IDAs and didnīt have any problems with it so far.
Tobi
Shane Noone
« Reply #10 on: May 30, 2012, 14:32:33 pm »
Cheers.
Hi,
Tobi
Hi Martin, I use same as Tobi here and have mine set to 3 psi on my 51 IDA's and seems ok, although I did have a troublesome gauge which I changed out. When JMR dyno'd mine think he used a Holley set up and tested at 2.9 - 3.0 psi.  Seems some people on here have suggested 3.5 - 4psi on IDA's.....
Tobi/DFL
« Reply #11 on: May 30, 2012, 14:56:18 pm »
Mine is set at 3 psi (according to the cheap gauge) as well.
stretch
« Reply #12 on: May 30, 2012, 16:07:29 pm »
Thanks guys.
Shane do you run jaycee style inlets on your carbs?  I nearly had a disaster on Sunday, the ally fuel block off in the side of the left hand carb had worked loose.  It was about 2 turns from falling out !!   Shocked  I smelled fuel & couldn't see any problems under the bonnet around the fuel tank, so started the engine & asked my wife to see if she could anything.  She started yelling for me to turn the engine off, fuel was spraying out of the left hand carb & pooling on the tinware.  So lucky it didn't ignite on the exhaust.  Needless to say i'll be checking those at regular intervals from now on.
Shane Noone
« Reply #13 on: May 30, 2012, 16:41:21 pm »
Thanks guys.
Martin, Jeez mate that was lucky !!  Shocked No, I don't have the Jaycee kit on mine - entry point is factory with some small neat alloy elbows. I mean't to say on Saturday if we at the track and you want to try a pass with my DOT's to see how much " instant" affect that has on your ET's let me know as no probs and you never know eh  Wink
stretch
« Reply #14 on: May 30, 2012, 18:39:18 pm »
Thanks for that Shane, Andy Joyner offered me the use of his dot's on Sunday, I stuck with my crappy van tyres & car went 13.2 @ 99mph.  That's a PB (in that car) for me mate so I was well happy.  I'm sure with a good track & better air than we had at the weekend there's a very high 12 in there somewhere.  Wink
