October 13, 2026, 10:09:52 am
| | |-+  What engine bearings you guys use?
Author Topic: What engine bearings you guys use?  (Read 16814 times)
181
« on: June 01, 2012, 15:20:20 pm »
With upcoming refresh of my 2276 I started to investigate what are the possibilities on the market. What main/rod/cam bearings are good these days?
Thanks,
Jan
viNce
« Reply #1 on: June 01, 2012, 19:00:09 pm »
Clemex main and cams bearings, clevitte rods.
You can also find some old steelbacked K&S.
« Reply #2 on: June 02, 2012, 06:01:43 am »
i don't see too many problems with what i use for the rods (even sinter metal or what it is called seems to hold up just fine)
cam bearings may need some filing on the trusts (KS and Mahle), but again no big problem just some attention that it all works
and if you are able to find steel backed center bearings i would suggest that. you come across them, but stay away from corroded or tarnished sets as they usually are beyond their expiration dates.
Erlend / bug66
Global Moderator
SCC Event
« Reply #3 on: June 02, 2012, 19:20:20 pm »
Old KS main bearings found in a shop in Oslo.
New KS rod bearings
Mahle cam bearings
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
pupjoint
« Reply #4 on: June 03, 2012, 02:39:04 am »
last build i used
Greg G
« Reply #5 on: June 03, 2012, 05:09:57 am »
I try to find NOS steel backed Kolbenschmidt main bearings, but I did try a set of silverline bearings on the last street motor build. I havn't taken it apart, but it has quite a few miles on it so far with out issue.
pupjoint
« Reply #6 on: June 11, 2012, 07:06:23 am »
http://www.thesamba.com/vw/classifieds/detail.php?id=1317551
« Reply #7 on: July 03, 2012, 21:15:16 pm »
wow, today I received a package of Brasilian Kolbenschmidt bearings and all I can say is that these are not going to my engine... Shocked
« Reply #8 on: July 03, 2012, 21:42:22 pm »
I use the new clyco csp sells now. best quality
DWL_Puavo
« Reply #9 on: July 04, 2012, 09:05:32 am »
Even if you're staggered with your bearings, pics explaining this a bit would be nice  Wink Just installed 2 sets of Kolbenschmidts with no other problems than misaligned oil feeding hole in CB alu case.
pupjoint
« Reply #10 on: July 23, 2012, 03:48:16 am »
Does Clevite make any STD Type 1 main bearings?
cel
« Reply #11 on: July 23, 2012, 20:57:10 pm »
Hi!
Yes they do, page 627 http://www.mahle-aftermarket.com/C125790900540AC0/vwContentByUNID/58A5032D3003098AC12579AB00615520/$FILE/EB-10-07.pdf
Regards
Marcel
