June 09, 2026, 22:19:18 pm
mvptkfjb
Lil Snort
Topic: Lil Snort (Read 26844 times)
Roller crankshafts
Lil Snort
June 12, 2007, 20:11:54 pm »
Russel what do you want to know about the car?
Russell
Re: Lil Snort
June 14, 2007, 23:04:06 pm »
1st question is How tall are you ?
I plan to take her up the strip at EBI but am very worried about my manhood, the steering wheel is like a weapon........ I have looked at a tempory measure to move it to make it more driveable for me, Im not the smallest or lightest guy in the world.
The fuel injection set up is pretty awesome but would love to know how and what size of Pills work better for using normal Pump Gas ? I seem to be flooding it on start up too easily !
Best Regards
Russell
Re: Lil Snort
June 15, 2007, 04:49:01 am »
Quote from: Russell Ritchie on June 14, 2007, 23:04:06 pm
Ever the master of understatement...
Russell
Re: Lil Snort
June 15, 2007, 07:21:44 am »
Keith
Thanks.
Best Regards
Russell
Martin
Cash Converter....
Re: Lil Snort
June 15, 2007, 11:53:00 am »
Ive got pills and Nozels for regular Gas, but why dont you run it on methanol like it should be?
IŽll have loads with me you can use some of that. also got a range of pills for the methanol.
I have a starting Procedure with woper,
1) Shut the fuel off
2) shut the mag down
3) Crank for oil (this should also help prime the fuel system)
4) I squirt a small amount of regular Gas (petrol) down the inlets
5) Arm the Mag
6) crank the motor (it should fire then stall)
7) turn on the fuel
crank the motor and away she goes!
I do the first fire of the day with regular gas as it get a little heat in the heads and help the methanol fire up.
what ever you do dont keep cranking the motor with the fuel on and no mag as it will hydrolic. Once your all up and running you just crank the motor and turn on the fuel and thats it
i found that my hilborn system drains down even with the fuel tap off so becarfull if the car is sat with a full tank of fuel, it will fill the motor up!
at the end of racing i just drain the tank, put some regular fuel in and run it with the shut off valve half closed (leans it out) and it help keep the lines clean.
Good luck
Martin
Last Edit: June 15, 2007, 14:50:50 pm by volksman
Martin
www.taylormachine.co.uk
OFF/500
Roller crankshafts
Re: Lil Snort
June 20, 2007, 09:06:17 am »
Russell,
I am 5'8" at 140. The car, as all professional race cars are, was made to my size. Did you run the car? The injectors are different than carbs. You have to prime the car to start it. You have to run them fat at idle and then it leans out around 7,500 rpm. You have to remember that was the only thing we had to go with back then was track conditions, temp, and elevation played a very important part. Today computers are used to control fuel flow. When Simon bought the engine from me he was minus the heads and cylinders. We ran the 82 roller with 88 or 92 cylinders. The heads were the trick in making the HP out of the injectors. Ratio was somewhere in the 12.5 to one of course gas was much better octane back then. We did run 10.80 on al but had to ware a firesuit!
The car gets a lot of wind in the floor where the front struts that come through the pan and are connected to the tunnel. If I were you I would use a boot, maybe a trans boot, to block off the air flow. Also the lexan glass windows in the doors should be tightened up with rubber or something. At 120 the windows flex and want to blow in past the opening. The car has a tendency to run on the back wheelie bars through first and second so a good heavy battery in the front helps hold the front end down. One more thing always and I mean always shut off the fuel then the mag at the top end. The mechanical pump on the injectors has to be shut off first. If you don't the engine will run even with the mag switched off which can cause all kinds of problems. I have not seen the car since I sold it back in 1997 but I would also check the front tires to make sure they are in good shape. If I was going to race the car today I would make sure all old rubber was replaced. Going through the top end at 120 can be a little harry. Try and never lift till you run through the lights and shut the fuel off. If you lift early the car can actually fly and become hard to control, hence forth the scar on the front fender at Lyon's drag strip 1973. Remember the downward force keeps the front end down so as long as you have your foot in it and stay in the rubber path the car goes straight as an arrow. I was the only driver that ever drove the car and of course there was no passengers. The roll bar saw to that.
Gary
ESH
Re: Lil Snort
June 20, 2007, 09:26:48 am »
Quote from: Roller crankshafts on June 20, 2007, 09:06:17 am
...Try and never lift till you run through the lights and shut the fuel off. If you lift early the car can actually fly and become hard to control, hence forth the scar on the front fender at Lyon's drag strip 1973...
Awesome post!
Useful advice for Russ and an great read for everyone else. In short stick Russ in a firesuit and tape the pedal down.
lowfastbus
WUNDERWAFFE
Re: Lil Snort
June 20, 2007, 10:34:13 am »
Wow, great post
Good to scare anyone willing to drive it!! If I remember right the car was driven once in England by Ian Clark... they did a 13 second pass or something like it...
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Re: Lil Snort
June 20, 2007, 17:56:47 pm »
here's the picture from that run & the team who made this possible
Re: Lil Snort
June 20, 2007, 18:36:05 pm »
roller crankshafts are you gary holzenecht
the owner/driver of lil snort
have you some other story about that car i never saw a picture of lil snort in the old vw magazine , did you have some old pictures too post
another question: to how much bug in the car such ran , and to which other dragraces such she ran
regards
Roller crankshafts
Re: Lil Snort
June 30, 2007, 05:00:29 am »
Thanks for the picks. It was fun seeing the car in action again. I noticed that the mag was missing. Maybe Simon did not sell it to ya or could not get it to work. Fuel injection works much better with a mag. Better spark. When I sold the car to Chris Andrews I let him (Borrow) all my old pictures. He never returned them!! Maybe if anyone knows how to get a hold of him and shamed him into returning the pictures I could post them here on the web. The pictures showed the building of the car in many steps and a few at the track at bug-Ins. Please Chris return the pictures. I was approached several times in the 70's to do articles on the car by Hot VW's and a magazine called Great Volkswagens. Please remember at the time we were inventors. The car has several trick things about it for its time. We did not want the competition to learn our tricks. I turned down several requests for articles. Looking back on it I guess I should of done a few articles, but at the time we wanted to be secret about the car. I was partly sponsored by Hilborn and we were the only drag car running their injection at the time. Also the front end of the car we ran a drop axle Angela spindle mount with 12 spoke hildabrand mag wheels. The wheels looked really cool but were a pain in the ass to keep polished, not to mention no front brakes. We would bag them when the car was not in service to try and keep them polished. The rear wheels were Deano Dyna Soars. We had several trans in the car. For a while we ran a 3 speed Linco Automatic. The trans worked well till we twisted an axle (like a pretzel) and broke the trans. Oh well enough of that stuff for now. Would anyone like to see my current project?
Gary
Re: Lil Snort
July 02, 2007, 10:09:51 am »
cool gary for the info and story , for the pictures the first time i saw lil snort at volksworld in 2001 there a 2 panels with old pictures from lil snort i looking for that picture of the lil snort at vowo
and now pictures of lil snort at european bug in this week end
Re: Lil Snort
July 02, 2007, 10:10:59 am »
return form the dragstrip
Re: Lil Snort
July 02, 2007, 21:24:33 pm »
Here's a couple we took a PATS
gingabloke
Re: Lil Snort
July 03, 2007, 11:40:15 am »
A few pics from Goodwood FoS 2002...
It's only a bodge if it fails...
Roller crankshafts
Re: Lil Snort
July 03, 2007, 16:54:01 pm »
Great shots! Sure brings back old memories. Yes the roll bar is right in front. Kind of a slight design flaw but if you know your history many of these gassers went flying at the top end. When Deano went upside down we were next in line in the staging lanes. Not a pretty picture. After seeing that we felt the roll bar was just a minor inconvenience. Oh one more thing about the car. A lot of people ask who did the graphics on the car. A guy, older gentleman, called Shakey Jake was famous in the 70's for pin striping VW's. I contracted Shakey to do the graphics and he did some drawings on paper that we liked. On the Saturday morning we towed the car to his shop Shakey was to hung over from the night before to do the job. He had his apprentice do the job. That is real gold leaf by the way. Somewhere in the drawing he signed it. Also the "Few things in life work as well as a VW" was taken from a Volkswagen add back in 1969.
Gary
sam P
Re: Lil Snort
July 05, 2007, 03:21:12 am »
Great stuff, Gary! To me it still looks like one of the meanest cars ever made. Nice to hear you're still into vw's too. What are you working on right now?
Re: Lil Snort
July 07, 2007, 21:16:41 pm »
yeah come on Gary lets see the new project
Chris Andrews - The Mailman
Gaelic lineage with Yankee blood
Re: Lil Snort
May 10, 2008, 08:16:03 am »
Quote from: Roller crankshafts on June 30, 2007, 05:00:29 am
Gary
UPDATE: I returned all of the pictures back to Gary. In fact, I even included a few unpublished images of the Stutt Bee when it was a competitor in NHRA's H/GAS. Gary, as I had said to you over the telephone, I am sorry for the delay in the return of your photos. I am happy that now we can put that matter to rest.
Respectfully,
"A simple way to take measure of a country is to look
at.....how many want in.......and how many want to get out."
-Prime Minister Tony Blair of Great Britain
"...Government of the people, by the people, for the people, shall not perish from the Earth."
-Abraham Lincoln, Gettysburg Address, November 19, 1863
"A man's country is not a certain area of land, of mountains, rivers, and woods, but it is a principle and patriotism is loyalty to that principle."
- George William Curtis
"Good fences make good neighbors."
- Robert Frost, The Mending Wall - 1914
jamiep_jamiep
Re: Lil Snort
May 16, 2008, 09:02:35 am »
Where's the details on this new project then Gary,, the suspense is killing me?!
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Mangokid
"Inhale the world", (in memory of MH)
Re: Lil Snort
August 15, 2013, 10:04:55 am »
Very old topic, I know, but are there any pics available from the Snorts front "suspension"? I've never seen it "live" so never got the chance to study it.
regards
Mango
To really know the edge and what lies beyond, one must have passed it.
SixGun
Re: Lil Snort
August 15, 2013, 11:40:53 am »
Quote from: Mangokid on August 15, 2013, 10:04:55 am
regards
Mango
...if you ever need an Anglia frontend, i have a spare one for you if you want it (with spindles etc)
Re: Lil Snort
August 15, 2013, 12:56:09 pm »
the front suspension was modified this year , the car returned to a vw front beam ,because it seems that the old started to broke that's why the lil snort had new wheels this year at EBI
Last Edit: August 15, 2013, 12:58:12 pm by speedwell
Re: Lil Snort
August 15, 2013, 13:01:52 pm »
here's a original shot from lil snort with out the body
Re: Lil Snort
August 15, 2013, 13:19:40 pm »
Love this thread!
Thanks for bringing it life again.
Some of my cars:
SixGun
Re: Lil Snort
August 15, 2013, 13:20:43 pm »
That axle is a fabricated drop axle, and not one from an Anglia - but most probably Anglia spindles as stated above (very common on gassers and dragsters back in the days).
Anglia axle could probably be used though, for anyone who wants to build something similar... i believe trackwidt on the Anglia is much more narrow than on a vw bug, not sure how much though - have to measure.
folkevogn
Re: Lil Snort
August 15, 2013, 13:25:04 pm »
Quote from: speedwell on August 15, 2013, 13:01:52 pm
Thats a really cool picture!! Top 3 of coolest vw gasser ever! shame to see the old front suspension removed
It completly changes the apperance of the car. Why not set up the front suspension for the old 12 spokes, like Alien Bug?
Folke Vogn
Last Edit: August 15, 2013, 13:28:01 pm by folkevogn
11.96 @ 180kmh - SCC 2013
Re: Lil Snort
August 15, 2013, 14:50:26 pm »
AMAZING!!!!!!!!!!!!!!!!!!!! Thanks Fabs
Mangokid
Re: Lil Snort
August 15, 2013, 18:11:07 pm »
Oh holy moly Mother of Jesus...why I even ask? There's drool all over my Laptop now, who's gonna clean that up? Thanx a lot
Mangokid
Re: Lil Snort
August 15, 2013, 18:13:39 pm »
Quote from: SixGun on August 15, 2013, 11:40:53 am
regards
Mango
Bring it on, PM me, how much?!? etc. I'm dying here.
