September 22, 2026, 07:09:23 am
| | |-+  1967 Baja bug project
Author Topic: 1967 Baja bug project  (Read 12441 times)
Wired1
« on: June 09, 2012, 23:06:34 pm »
In this part of the world the 67 beetle was still a wide-five swing axle beast until 68-69 so this car probably looks like an older beetle to you northern hemisphere guys. I bought the donor beetle three or four years ago from a local guy who had done the rust repairs then run out of steam. It has the heater channels and all the other rust work down plus he overhauled the 1300 gearbox which was a bonus as he is a diesel mechanic and reckoned it was dead easy.
The car had had some front impact damaged repaired at some time and still has a few signs on the front apron of the repair so it's a good candidate for a baja. So basically it's a rust-free beetle ready for the chop, just want I wanted.
I picked up the one-piece front end kit a year ago from a mate in Christchurch who is also building a baja and had scored the moulds. I also have all the fixings to do an IRS conversion on the rear end but I might end up leaving it swing-axle if it sits alright on the road. I have already spoken to my certification guy and he has agreed to do the cert on the wheels, motor and body changes and says he will do it all at the end now that he has seen the car and knows my plans for it. In this country a car has to pass a rigorous inspection every six months to remain road-worthy plus certification if anything is altered lik in this car.
The story so far then, I brought the car home from where I have had it stored for the last few years in my workshop in Richmond, South of Nelson. And first up I cut the front apron off and trimmed the one-piece nose to fit the body. It took all day to trim the nose as it is hard to measure and you can only cut bits off - any cock-ups and you're buggered basically. But it got there eventually and sits pretty well on the body. I will trim it slightly more when I have made up the hinge unit for the tilt-front.
I also started on the rear guards and will cut the back off tomorrow unless something else distracts me from doing it.
1967 baja project - 1963 beetle driver - http://www.youtube.com/user/wiredkiwi
Wired1
« Reply #1 on: June 09, 2012, 23:07:19 pm »
Day two - cut the back off. Loads easier than the front, you just bolt the guards on and get stuck in with the cutting disk. Also painted the rear guards and inside the engine bay. I need to find a nice quiet exhaust setup before I build the engine cage.
Wired1
« Reply #2 on: June 09, 2012, 23:08:04 pm »
Been cleaning up the spare motor for the baja this weekend, with it all on show it's got ot look pretty. I'll eventually build something bigger but for now the 1600 twin port will do the trick
Wired1
« Reply #3 on: June 09, 2012, 23:09:13 pm »
Another day and got some quality time in the shed this afternoon. The tilt-front is eating up a heap of time but it is nearing completion.
Today I made the brackets to hinge it from the front of the body and trimmed the fibreglass again slightly. It is a nerve-wracking experience trimming the fibreglass as you can only cut more off Smiley
The hinge plates will also carry a nudge bar across the front.
Wired1
« Reply #4 on: June 09, 2012, 23:09:47 pm »
Fooling around with the dash today. I'm using a late model speedo which has the fuel gauge in it. I've added a vdo tacho plus two oil guages, a voltmeter and a clock.
I'll keep the stock glove box and I'm going to try and fit a stereo into the old ashtray area if it will go.
Wired1
« Reply #5 on: June 09, 2012, 23:10:27 pm »
Fitted the motor today to see how it is going to sit with a bit of weight on it. I've got a couple of other projects on the go too so progress is a bit slow at the moment.
Wired1
« Reply #6 on: June 09, 2012, 23:11:29 pm »
Cut the rust out of the engine lid this afternoon Smiley
This is the mockup of the licence plate and tail light - turn signals will go on the rear nudge bars I think, not sure.
Wired1
« Reply #7 on: June 09, 2012, 23:11:59 pm »
New video of most of the stuff so far...
<a href="http://www.youtube.com/v/PUHCSqX_2YM" target="_blank">http://www.youtube.com/v/PUHCSqX_2YM</a>
« Last Edit: June 09, 2012, 23:16:34 pm by Wired1 » Logged
Wired1
« Reply #8 on: June 09, 2012, 23:18:52 pm »
Another public holiday today so I built one of these:
Got new video editting software so any excuse to make a movie...
<a href="http://www.youtube.com/v/djkxYydhK5M" target="_blank">http://www.youtube.com/v/djkxYydhK5M</a>
Richyrich
« Reply #9 on: June 10, 2012, 00:28:45 am »
Nice work Bud. Bajas are so Cool. Grin
