June 10, 2026, 07:31:07 am
Latest Member: mvptkfjb
| |-+  Wanted
| | |-+  WANTED: Zenith 32NDIX for Volkswagen
Author Topic: WANTED: Zenith 32NDIX for Volkswagen  (Read 12929 times)
« on: June 13, 2007, 18:32:05 pm »
Looking for good 32NDIX for use as single carb on 1800cc VW
Please PM me or sheep
Thank You!
« Reply #1 on: June 13, 2007, 20:08:10 pm »
carb and single port manifold Samba Ad number: 359789
Zenith carb and single port manifold   Price: $125
used, untested 32 NDIX Zenith carb and single port manifold
$125
_________________
all prices plus shipping ,
if you are not in the USA and need shipping info , please tell me,
« Reply #2 on: June 13, 2007, 20:11:30 pm »
Zenith 32 NDIX Carb & Air Cleaner Samba Ad number: 464112
Zenith 32 NDIX Carb & Air Cleaner   Price: $75 obo
Vintage Solex Zenith 32 NDIX DVGcarb with a cool old school air cleaner assembly & base. Carb is in good shape but it's been in storage for many years & will need a rebuild. Appears complete. Throttle shaft is not worn out. Carb body stamped "P03R".
Buyer pays shipping, send a zip for a quote.
« Reply #3 on: June 13, 2007, 20:15:04 pm »
Zenith 32 NDIX Carb, Mani, Air Cleaner Samba Ad number: 465823
Zenith 32 NDIX Carb, Mani, Air Cleaner   Price: $225.00us
For sale. (1) Completely rebuilt Zenith 32 NDIX carb. The throttle shaft has been replaced with a new custom made brass unit, new thottle shaft bushings replaced with custom made impregnated bronze bushings, teflon throttle shaft seals installed, New complete gasket kit installed. Also included (1) Brand new Uni-filter two-stage filter element & mounting base and top, (1) Bugpack Zinc coated manifold. Any questions ask away.
_________________
Buy the Best and Only Cry Once.
« Reply #4 on: June 14, 2007, 02:21:20 am »
Here is a direct link to the above adds.
http://www.thesamba.com/vw/classifieds/search.php?submit=yes&keywords=zenith&type=text&stype=all&username=&yearfrom=&yearto=&pricefrom=&priceto=&model%5B%5D=&section%5B%5D=&wanted=show&zip=&zipdist=0&state%5B%5D=&usaregion=&country=&sort=date&sort_order=DESC&submitButton=Search
« Reply #5 on: June 14, 2007, 06:49:41 am »
You DO NOT want carbs that are stamped PO3R, PO3L, PO19R, PO19L- those are intended to be run as duals on a 356 engine. Im told the circutry is all wrong for a single application. Look for carbs that have the extra arm to attach the throttle cable with a barrell nut like the stock carb has- its a good chance that those carbs are marked either PO10, or just PO like mine is- intended as a single carb. I also believe that they run best with an isolated runner manifold, no plenum. Good luck Jim, Ill keep an eye out for you.
bathing ape
« Reply #6 on: June 14, 2007, 08:59:10 am »
jim i'm gonna pm some details of a zenith32ndix which i just nearly bought from the u.s until i found out it wont clear my ghias deck lid,i have the empi filter for it if you want one of those
simon uk
« Reply #7 on: June 14, 2007, 10:51:58 am »
hi bathing ape, i will takethat empi air filter if jim doesnt go for it. i am in hospital at the moment, butwill keep checkng my pms!
cheers si.
bathing ape
« Reply #8 on: June 14, 2007, 11:01:12 am »
ok simon
« Reply #9 on: June 16, 2007, 18:39:15 pm »
http://www.thesamba.com/vw/classifieds/detail.php?id=467494
bathing ape
« Reply #10 on: June 16, 2007, 18:56:10 pm »
thats the one i was on about jim
