August 12, 2026, 16:54:17 pm
| | |-+  traction bar on Roger Crawford's 67
Author Topic: traction bar on Roger Crawford's 67  (Read 9456 times)
pupjoint
« on: June 18, 2012, 04:49:33 am »
Anyone has or using the same traction bar as found on Roger's black 67? more info? detailed pics?
current have the Berg mount, yea they work OK, but personally dont like the way it is mounted, prefer something i can bolt to the block.
Doug Mische's old 67 also had a similar mount like Roger's, wondering how they look like from below and if they are selling it as a kit.
« Last Edit: June 18, 2012, 04:54:23 am by pupjoint » Logged
« Reply #1 on: June 18, 2012, 06:00:49 am »
I have  a nice metal that can get bolted to the case around the oil pump. gets bolted to the original bosses on the case if you have threads in it
pupjoint
« Reply #2 on: June 18, 2012, 06:14:07 am »
any pics Udo? any rubber mounts? how does it mount to the body? just drill a hole , or you need to weld in some mount pieces?
« Reply #3 on: June 19, 2012, 20:23:35 pm »
i only have dones these for bolt on the case , so you can use your own made bar
-Alex-
« Reply #4 on: June 19, 2012, 21:07:16 pm »
I  have sold my std  traction bar, and also planning to design with solidworks a new one that bolts to case, most of the parts will be lasercut ones.
« Reply #5 on: June 19, 2012, 22:43:02 pm »
Do you have these still available Udo? I suspect the 3 holes are for the bolts that go through the traction bar? Does the tractionbar still 'hit' the case with your plate?
« Reply #6 on: June 20, 2012, 05:49:01 am »
Yes i have some of these , 2 holes for bar and 3 for bolting on the case
ESchey56
« Reply #7 on: June 20, 2012, 22:43:37 pm »
The traction bar on Rogers car was build by Competition Engineering in Phx for the previous owner.
pupjoint
« Reply #8 on: August 09, 2012, 05:35:53 am »
udo u mean the 2 holes in your plate bolts to the case, and 3 for the bar?
karl h
« Reply #9 on: August 09, 2012, 06:59:42 am »
yes, these. they take the stock rear engine mount on baywindows and have enough rigidity
