September 25, 2026, 02:59:47 am
tool??
Topic: tool?? (Read 6993 times)
banditina
tool??
June 18, 2012, 12:19:45 pm »
What is this?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-5102
www.stinkingass.blogspot.com
http://die-kriegs-maschine.blogspot.com
http://www.oldclan.it
IF YOU THINK YOU'RE TOUGH INSULT A KAFERMAN!
Jesse/DVK
'64 2176cc
Re: tool??
June 18, 2012, 12:43:17 pm »
I believe it is for removal of the nut that holds the original oil filler/breather.
Re: tool??
June 18, 2012, 13:33:48 pm »
Quote from: Jesse/DVK on June 18, 2012, 12:43:17 pm
Correct
Re: tool??
June 18, 2012, 13:51:53 pm »
Is there a homemade workaround for that job?
Re: tool??
June 18, 2012, 14:32:54 pm »
I've had limited, but occasional success using to Large screw drivers ... one placed in each slot, then cross them against each other ...
Unfortunately these things are usually torqued down SUPER tight or stuck!
That particular tool can be found at most plumbing supply shops .... it's a 1" internal pipe wrench, nothing
special!
TxT
kingsburgphil
Re: tool??
June 18, 2012, 15:21:01 pm »
Quote from: TexasTom on June 18, 2012, 14:32:54 pm
special!
TxT
X2. And in a worse case scenario can crack the nut and the stand. The factory style tool is a face pin spanner.
Re: tool??
June 18, 2012, 15:32:13 pm »
special!
That's a valuable piece of info! I'll see if I can find one locally for cheap.
Luckily, I don't need to remove the nut, just reinstall and tighten!
56BLITZ
Re: tool??
June 18, 2012, 18:12:21 pm »
At one time, there was a "spanner" type tool made to fit on the end of a 3/8" ratchet extension . . . is it still made?
Jesucristo es mi Seņor y Salvador!
Re: tool??
June 18, 2012, 18:19:36 pm »
make one, use an old socket and weld on some square tubing of the correct size.
kingsburgphil
Re: tool??
June 19, 2012, 02:21:57 am »
Quote from: kingsburgphil on June 18, 2012, 15:21:01 pm
special!
TxT
I think this is what he had in mind
http://www.jbugs.com/product/5761.html?Category_Code=vw-specialty-puller-remover-tools
Re: tool??
June 19, 2012, 03:18:24 am »
Quote from: Lids on June 18, 2012, 18:19:36 pm
WIN! I've seen those made. Way more effective and easy to fabricate.
Kaferdog
Re: tool??
June 20, 2012, 08:29:43 am »
Yeah I have one of those from waaayback ....!...I think if it were to be a little thicker it would be a bit more stable ..Sometimes it has tendencies to slip...maybe a little more weight...?
banditina
Re: tool??
June 22, 2012, 08:33:31 am »
TNX guyz!
