May 20, 2026, 15:46:13 pm
Latest Member: mvptkfjb
| | |-+  tool??
Author Topic: tool??  (Read 6371 times)
banditina
« on: June 18, 2012, 12:19:45 pm »
What is this? Huh
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-5102
« Reply #1 on: June 18, 2012, 12:43:17 pm »
I believe it is for removal of the nut that holds the original oil filler/breather.
« Reply #2 on: June 18, 2012, 13:33:48 pm »
Correct Smiley
« Reply #3 on: June 18, 2012, 13:51:53 pm »
Is there a homemade workaround for that job?
« Reply #4 on: June 18, 2012, 14:32:54 pm »
I've had limited, but occasional success using to Large screw drivers ... one placed in each slot, then cross them against each other ...
Unfortunately these things are usually torqued down SUPER tight or stuck!
That particular tool can be found at most plumbing supply shops .... it's a 1" internal pipe wrench, nothing special!
TxT
kingsburgphil
« Reply #5 on: June 18, 2012, 15:21:01 pm »
TxT
X2.  And in a worse case scenario can crack the nut and the stand. The factory style tool is a face pin spanner.
« Reply #6 on: June 18, 2012, 15:32:13 pm »
That's a valuable piece of info! I'll see if I can find one locally for cheap.
Luckily, I don't need to remove the nut, just reinstall and tighten!
56BLITZ
« Reply #7 on: June 18, 2012, 18:12:21 pm »
At one time, there was a "spanner" type tool made to fit on the end of a 3/8" ratchet extension . . . is it still made?
« Reply #8 on: June 18, 2012, 18:19:36 pm »
make one, use an old socket and weld on some square tubing of the correct size.
kingsburgphil
« Reply #9 on: June 19, 2012, 02:21:57 am »
TxT
I think this is what he had in mind
http://www.jbugs.com/product/5761.html?Category_Code=vw-specialty-puller-remover-tools
« Reply #10 on: June 19, 2012, 03:18:24 am »
WIN! I've seen those made. Way more effective and easy to fabricate.
Kaferdog
« Reply #11 on: June 20, 2012, 08:29:43 am »
Yeah I have one of those from waaayback ....!...I think if it were to be a little thicker it would be a bit more stable ..Sometimes it has tendencies to slip...maybe a little more weight...?
banditina
« Reply #12 on: June 22, 2012, 08:33:31 am »
TNX guyz!
