September 22, 2026, 09:00:25 am
| | |-+  a '67 Transaxle with a Doghouse?
Author Topic: a '67 Transaxle with a Doghouse?  (Read 5635 times)
56BLITZ
« on: June 23, 2012, 07:29:11 am »
I have what I believe is a ‘67 transaxle . . . 12 volt, short splines, long tubes, two-prong switch in the nose cone. The upper left hole in the bellhousing has a provision to hold the head of the bolt, but it does not work so well with a late ( doghouse ) engine case that has the insert. Should I grind a couple flat sides on a washer to fit the trans case, or should I grind those things off of the trans case, or is there some other way for me to tighten that top bolt?
« Reply #1 on: June 23, 2012, 08:26:43 am »
I use either a thick spring washer with a normal bolt which can be a pain to tighten the last couple of turns,or an Allen bolt with washer with allen socket/ratchet with no problems at all
« Reply #2 on: June 23, 2012, 09:18:45 am »
Grind them off the trans case.  It upgrades it to the later trans case spec.
bugnut68
« Reply #3 on: June 27, 2012, 00:56:57 am »
Yep, that's what I did on my '70...
56BLITZ
« Reply #4 on: June 27, 2012, 08:03:58 am »
Thanks for the help folks!
I agree . . . those things have to go.
This will be the trans for my new project. I am stoked to get started on it!
