October 15, 2026, 19:58:26 pm
Valve Springs?
Topic: Valve Springs? (Read 9681 times)
andy198712
Valve Springs?
June 28, 2012, 13:20:19 pm »
What would you all use and what installed height ect for this engine.
2180, daily driven ish. in the UK
CB044 40x35 valves
engle FK8 cam
bugpack forged 1.4's
i'm guessing dual springs but which ones? or the honey comb ones?
All the best
Andy
andy198712
Re: Valve Springs?
June 28, 2012, 13:21:06 pm »
forgot to add, i wont be racing it. wont see more then 6-6.5k ever and even that rarely (he says)
Re: Valve Springs?
June 28, 2012, 14:13:40 pm »
Is the valve stem height not already set?
What are the rest of the valvetrain components ... lifters, pushrods, retainers, etc.? It all adds up! LOL
TxT
henk
Re: Valve Springs?
June 28, 2012, 19:46:36 pm »
i have a set springs for sale.
i never used them they where in the heads that i bought but had to change them with cb vw650
henk!!!
andy198712
Re: Valve Springs?
June 28, 2012, 20:00:27 pm »
Quote from: TexasTom on June 28, 2012, 14:13:40 pm
TxT
I thought spring height was when you shim the springs? I may be way off lol
Cb Bigfoot lifters, yet to buy pushrods but will be hd Alu, and the retainers are the cb ones, chromoly I think they are, again cb single groove collets,
Hoover mods and will probably drill a small hole in the pushrods to act as oil squirters.
Dry sump, crank Fired ignition, EFI.......
Hope that helps
Re: Valve Springs?
June 28, 2012, 21:45:13 pm »
The cam seems a little big for that rpm,with it I would be shifting about 6800/7000rpm,you may need to machine the valve guide and boss down a little but will only know that when you roll it over to find lift at the valve,unless you go with some exotic spring combo then a vw dual will work,the CB VW650 seems to be working well,and they seem to last better than alot of cheaper VW duals,and if you are going the lighter route with ally pushrods then spend a little more on the retainers and get the Ti version.
I will keep my opinion on 92s and bigfoot lifters to myself though
cheers richie
andy198712
Re: Valve Springs?
June 28, 2012, 22:46:48 pm »
Quote from: richie on June 28, 2012, 21:45:13 pm
cheers richie
Thanks richie,
If budget allows near the end of the build I may switch to tool steel lifters, I just got the big foots cheap tbh. And the only down side seems to be a little extra weight that will be voided by the Alu push rods.
I want to use Alu purely for the reduced noise, not so much for weight saving.
Do you think it's worth getting Ti parts on a daily?
I already have the dual springs that came on the cb heads, they have 1000 miles on them and when I live them up they are different heights..... So I'm guessing there junk?
With the rpm range. I guess I always like to have a little extra to call on now and again when the mood takes me, much like the power delivery on my ZX9R nice power and great for riding, and always has that massive reserve of power should I be in the mood
I'll get a picture of my current springs and you can see what I mean.
Andy
Re: Valve Springs?
June 29, 2012, 00:45:34 am »
If the valves aren't lining up in their heights ... That's a problem! Something wrong with the valve job or a seat (big surprise!).
ANYTHING you can affors to use that will lighten the valvetrain without sacrificing reliability is a good thing.
TxT
Re: Valve Springs?
June 29, 2012, 09:19:18 am »
cheers richie
I wondered about the 92's myself! Andy, why the 92mm pistons? If you've had no machining work yet then you may as well go for 94's, but if the work has been done then put in 90.5's - they're the same size holes in the case and head IIRC. That'll give you 2110cc, but the thicker wall barrels will be better for a regularly driven street car. 2110 might be better suited for the valve sizes too, although rpm will really be the limiting factor.
andy198712
Re: Valve Springs?
June 29, 2012, 11:24:50 am »
Quote from: TexasTom on June 29, 2012, 00:45:34 am
TxT
Duely noted about the weight saving, am I right in thinking it will raise the rev limit before valve float ?
I wasn't very clear, when the springs are removed from the head, lined up on the table, I can see they are slightly different heights. If that makes sense?
andy198712
Re: Valve Springs?
June 29, 2012, 11:30:10 am »
Quote from: Neil Davies on June 29, 2012, 09:19:18 am
cheers richie
Hello,
The heads and cases are 90.5 so wanted to stay at that.
I do actually have some used 90.5's but I really need to check them out, missing the odd fin too.
I gt the Mahles 92's new cheap, and thought the forged 92's would e better then the 90.5 which I'm guessing are cast? (any way to check?)
How long would the 92's last do you think?
I know they used to be the hot setup but.....
Can you explain the RPM bit? I guessed I'd rev it to those numbers just as I guessed that where it would sign off and for engine longevity ?
I'm totally open to opinions and ideas, I'm very much on a learning curve
Thank you very much for the input, it's very helpful!!
andy198712
Re: Valve Springs?
July 02, 2012, 22:38:32 pm »
well, i think i'm going to sell my 92's in favour of the 90.5s....
