October 13, 2026, 20:04:25 pm
| |-+  For sale!
| | |-+  2275 race/street engine
Author Topic: 2275 race/street engine  (Read 4409 times)
volkmaster
« on: July 02, 2012, 15:30:42 pm »
[ Attachment: You are not allowed to view attachments ] Engine was built by JayCee 2008.
Case: CB mag with following modifications:
JayCee bypass oil system, sleeved lifter bores, cut for sandseal and flanged crank and center flanged bearing.
Oilreturns from heads to case. ARP 10mm cylinderhead bolts.
Crank: Flanged Bugpack 82mm w T4 center main and chevy rod journals.
Rods:  5,5" CB H-beam super race w ARP bolts.
Cylinders: JayCee
Pistons and rings: Venolia/Dykes
Cam and lifters: Engle FK89 w CB straight cut gears, CB 2pc racing lifters, Pauter pushrods.
Heads: Comp Eliminator w 46x38 stainless valves, port and polish by JayCee,. K800 springs, titanium retainers, CB 1,4 rockers and valve covers.
Fresh valvejob and intake liners.
Carbs: JayCee  IDA 51,5 carbs with all the tricks. JPM venturis 44mm, CB intakes and linkage.
Clutch: Kennedy stage1 and Blackmagic disc.
More: MSD distributor and wires, old but working MSD 7a with adjustable timing control and MSD blaster coil , 1-3/4 headers and coated stinger, 30mm oilpump, CB billet alu oil pump cover, JayCee oil bypass filter, CB deep oilsump. Polished aluminium crankcase breatherbox. Geers triggerbracket -MSD sensor is included.
Can be included for a turn key package:
Holley Blue fuelpump w regulator, dual fuel pressure gauges and steel braided fuelhoses.
Full cool-kit with polished aluminium fan housing/cylinder tins, polished generator w billet pulley and chromed stand.
Has about 50 passes and 20 dyno pulls.
Was recently taken apart and checked.
Has 12.5 Cr and runs fine on Shell V-Power.
On dyno 7 weeks ago: 226 hp @ 6900 rpm.
Can mail dyno curves if desired.
Building new engine as the new car has a gearbox with gears for 300+ hp…
Complete engine: 5200 (46000 skr) Euro
Fuel kit: 300 Euro (2500 skr)
Cool-kit: 250 Euro (2000 skr)
Can be seen at BRC at Tierp Arena 3/8 and if deposit is paid I can take it to SCC at Gardermoen 21-23/8.
At Tierp it ran 11.71 -183km/h without launch in a stock weight car with a 002-box geared way too high.
Put this in a lighter car with a tight sving-gearbox and you will do pretty low 11-sec runs.
Thanks for looking.
/Volkmaster
« Last Edit: August 07, 2012, 14:44:25 pm by volkmaster » Logged
volkmaster
« Reply #1 on: August 01, 2012, 14:10:18 pm »
Updated and pic! [ Attachment: You are not allowed to view attachments ]
« Last Edit: August 08, 2012, 08:23:02 am by volkmaster » Logged
volkmaster
« Reply #2 on: August 07, 2012, 14:45:23 pm »
Now with timeslip and a link to nice pics from BugRun Classic 2012.
www.RubNScrape.com
« Last Edit: August 07, 2012, 15:24:11 pm by volkmaster » Logged
