October 14, 2026, 05:32:52 am
2332 engine for sale!
Topic: 2332 engine for sale! (Read 4122 times)
tezer
July 05, 2012, 17:44:41 pm »
I have new built 2332 engine that I'm thinking to sell if the price offerd is right!
engine is not even broken in so have not tried it max, but it is amazing push in it!
its not dynoed yet so do not know for sure how much hp and torqe it is in it, but on paper it should be arund 200hp!
is 11-1 in compression but run fine on 98 octane!
the only reason that i consider and selling it is because I am interested in a turbocharged engine that is for sale!
it is a small leak on the push rod tubes. but has parts in order so it will be fixt, or the one that bay it can fixt him self whit a reduction in prize!
you can also run this engine whit the oil leak but i hate oil leaks!
engine is in the car and ready to run, all of the cooling tin is in place and there are also external oil cooler that sits next to the gearbox with a fan!
the motor runs 85cc oil temperature in mixed driving, the oil system is rebuild and have 2kg idle and maximum rpm 4 kg this is whit schadek o-ringd 26mm oil pump
it can be tested in car but i live in norway,but i have plans to go scc then you can try it out there if you like!
all inside the engine is messurd carfully and balanced to 0 her in norway!
have made A list of what the engine cost me, and it also tells the which parts are used in it!
Cb super pro heads 875
cb650 valve springs 109
stright cut cam drive 145
cb super race rods 250
chromoly push rods 60
dpr 84 crank whit chevy journals 380
clevite rod bearings 30
ks main bearings 40
1.4-1 ratio rockers 235
Bugpak long cylinders 130
wiseco pistons 360
total seal piston rings 85
kennedy 1 pressure plate 100
kush look disk 33
engle fk87 cam 100
engle lifters 65
cb big beef manifolds 70
atolinea alu case 700
1-5/8 exhaust 100
alu pully43
36Hp Doghouse Shroud W/ Heat 84
gene berg cooling fan 120
=4114usd
+ shipping $1,183.02
Balance work 249
dellorto 48mm trijet 600
total prize =5046 us
Last Edit: July 05, 2012, 17:47:38 pm by tezer
Green Goblin
Re: 2332 engine for sale!
July 05, 2012, 18:30:11 pm »
Hi,
Please could you confirm the selling price for me as I am not sure whether $5k was the build price or is the selling price now?
Many Thanks
Andy
www.DKRclub.co.uk
tezer
July 05, 2012, 19:07:23 pm »
build price was arund 5000us in parts,+ takses+ work so the total i had to pay 8000us!
but open for offers!
Green Goblin
July 05, 2012, 21:09:21 pm »
PM Sent
Andy
www.DKRclub.co.uk
