October 23, 2026, 20:30:01 pm
How much money to run 10s in a street car?now with part2, The evolution to turbo
18
19
20
21
36
Topic: How much money to run 10s in a street car?now with part2, The evolution to turbo (Read 1460840 times)
Re: How much money to run 10s in a street car?
Reply #540 on:
March 05, 2015, 20:03:32 pm »
Its all for cage stuff, will be same as old cab, 2 extra bars down from main hoop/harness bar area to torsion housing, so missing pieces are to allow welding it to torsion housing, will fill it in after its done and the open area around where Z bar would mount is because it also goes across under package tray to each shock tower
Reply #541 on:
March 05, 2015, 21:30:24 pm »
Ah, makes sense! Mine has no boot floor, just a box where it would have been between the wheel arches. Still has most of the body mount and inner arch panel and the crossmembers but has a bar further back tied into the frame horns. I'm looking forward to seeing how the cage ties the torsions and shocks in as they're pretty much free floating at the moment! I've got some ideas which might end up with some mini tubs in there too. Just need time...
Reply #542 on:
March 06, 2015, 19:24:04 pm »
WhiteTrash
Reply #543 on:
March 06, 2015, 20:48:43 pm »
Reminds me when I had mine painted and saw it for the first time
Good work
HOFF#67
WCB Hitler's Hot Rod
Reply #544 on:
March 07, 2015, 15:44:19 pm »
Looking good Richie! Really looking forward to seeing this completed. I like the lotus white color.
Reply #545 on:
March 07, 2015, 18:38:12 pm »
Thanks Steve, should be a good fun street car to use & abuse
Reply #546 on:
March 07, 2015, 19:25:38 pm »
Quote from: WhiteTrash on March 06, 2015, 20:48:43 pm
Good work
thanks
whatever you paid it was worth it
Spent today making more things white, all the small things take so long even just to sand and prep
, now got all wings done, redid the bonnet as had a reaction in it, then stock decklid and lots of small stuff. then started trying to save the rear apron, the inner heat shield was rusted through, it had about 10mm of filler in it from previous repair and I had decided to do it like the old cab, after some beating, shaping, grinding etc it now is how I want it and got a good skim of filler last thing
dannyboy
Reply #547 on:
March 07, 2015, 23:39:42 pm »
lots of weight in the filler....
8.77@156.8mph
O/FF 60
kielbasa
Reply #548 on:
March 08, 2015, 04:22:54 am »
Here I am trying to remove filler off my car, and your there adding. Looking good buddy
dont you dare tell me turbo is better then N/A
Reply #549 on:
March 08, 2015, 07:46:30 am »
Quote from: kielbasa on March 08, 2015, 04:22:54 am
It will be quite thin once I work it, but the whole area needed a little, really it needed a new apron but budget doesn't allow that
Russell
Reply #550 on:
March 08, 2015, 13:55:26 pm »
Quote from: richie on March 06, 2015, 19:24:04 pm
Ive got to say that does look really good.... well done.
I can see it now Shitter Queen Restorations, poor gavin LOL
Best Regards
Russell
WhiteTrash
Reply #551 on:
March 08, 2015, 14:44:58 pm »
Quote from: Russell on March 08, 2015, 13:55:26 pm
Gavin has nothing to worry about.
This is more like Drag Queen Restorations. Same amount of filler on the apron as on Lilly Savage and Dame Edna's face
HOFF#67
Reply #552 on:
March 08, 2015, 14:53:48 pm »
Quote from: WhiteTrash on March 08, 2015, 14:44:58 pm
Sea nuts?
WhiteTrash
Reply #553 on:
March 08, 2015, 14:59:22 pm »
Get back in that garage, you got some filler to rub down
Should be able to take me for a spin when I come up at the rate you're going at
HOFF#67
Reply #554 on:
March 08, 2015, 19:58:15 pm »
Quote from: dannyboy on March 07, 2015, 23:39:42 pm
Lighter now
Reply #555 on:
March 08, 2015, 20:02:31 pm »
Brakes bleed, clutch cable re attached to pedal and then time to get the body out ready to go onto pan
Reply #556 on:
March 08, 2015, 20:08:49 pm »
With a little moving, aligning and moving, then moving etc etc I got the body down onto the pan, big moment for me as it finally starts to look like the idea I had in my head
Reply #557 on:
March 08, 2015, 20:18:28 pm »
Got all the pan to body bolts in, the usual dicking around to get everything to line up but all done now so started bolting stuff back on, needed some room so bonnet went on, replaced the 2 factory springs with one single gas strut to hold it open, the springs were to strong for the light fiberglass bonnet, this seems to work better
WhiteTrash
Reply #558 on:
March 08, 2015, 20:22:54 pm »
NICE
Looks great
HOFF#67
Paul Bahnstormerz
Reply #559 on:
March 08, 2015, 20:32:14 pm »
Looks good!
Reply #560 on:
March 08, 2015, 20:44:20 pm »
Quote from: WhiteTrash on March 08, 2015, 14:59:22 pm
I only stopped for the kettle and a quick lunch, and that as while paint was drying
Reckon if I had the gearbox and it wasn't going to Jim then I probably could have it finished in 2 weeks
Quote from: WhiteTrash on March 08, 2015, 20:22:54 pm
NICE
Looks great
Quote from: Paul Bahnstormerz on March 08, 2015, 20:32:14 pm
Looks good!
Thanks, how's yours coming along?
Last Edit: March 08, 2015, 21:45:26 pm by richie
tikimadness
Reply #561 on:
March 08, 2015, 21:24:47 pm »
Quote from: richie on March 08, 2015, 20:44:20 pm
NICE
Looks great
Probably still needs to be blasted
Michael
GASSER GARAGE a few friends creating history.
NIDGAFWYT
Russell
Reply #562 on:
March 08, 2015, 21:52:35 pm »
Richie
Well done shows what a lot of effort can do, speaks volumes for your attitude.
Russell
Best Regards
Russell
Reply #563 on:
March 08, 2015, 21:59:50 pm »
Quote from: Russell on March 08, 2015, 21:52:35 pm
Richie
Russell
So true. I also thought that Richie had a full on shop loaded with high end tools regarding what he already achieved with his cars. It also show that dedication will lead you to the top! Congrats for the work done Richie!
henk
Reply #564 on:
March 08, 2015, 22:09:04 pm »
looks really good.
seems to go fast now.
henk!!!
Reply #565 on:
March 08, 2015, 22:28:31 pm »
Quote from: j-f on March 08, 2015, 21:59:50 pm
Richie
Russell
I dream of those tools
but unless my lottery ticket wins they will just remain a dream, so have to do with hard work and a little imagination to get me through
thanks for the compliment though
Turbo_Rich
Reply #566 on:
March 08, 2015, 22:53:39 pm »
Looks fantastic, keep up the good work
Reply #567 on:
March 08, 2015, 23:01:01 pm »
Quote from: henk on March 08, 2015, 22:09:04 pm
looks really good.
henk!!!
As soon as I set myself the target of Cal look drag day in May it became easy to keep motivated, and I am enjoying doing it as well which helps when its is cold or raining outside to carry on
baz
Reply #568 on:
March 08, 2015, 23:26:46 pm »
Looks great. We have the same rotisserie as your one, only your car has come down off it now while mine has yet to go up. And we're both working to the same deadline too
I will prevail.
Reply #569 on:
March 09, 2015, 01:57:14 am »
Ritchie, thanks for those pics mate.
I rekn there's about 1/2 dozen ideas that either I'd wondered about or will try on my own for next time.
Thanks man!
Looking good too.
18
19
20
21
36
