October 24, 2026, 06:45:59 am
How much money to run 10s in a street car?now with part2, The evolution to turbo
5
6
36
Topic: How much money to run 10s in a street car?now with part2, The evolution to turbo (Read 1461410 times)
Re: How much money to run 10s in a street car?
Reply #90 on:
July 11, 2012, 11:59:30 am »
Quote from: Airspeed on July 11, 2012, 10:27:04 am
It is indeed a cool idea and one that will interest most everybody because as JHU put it: the triangle says no, however....
what cannot be underestimated here is the VAST knowledge Mr. Webb has with this subject. I think knowing 'exactly' what's neccesary and what not, is key here.
That experience is worth at least 5-10K alone
Walter
that is what I am hoping,I know you to set your aims for a 10 sec car,but I wont handicap myself but trying to make it go round corners,as long as it goes round roundabouts that will be good enough for me
I know what it needs from my experiences before,but back then it was a gradual evolution,this time I need to be straight on it,a couple of shakedown passes then open the bottle and hope I got it right,also some of the parts i used back then arent available anymore,hopefully there are other suitable parts but I wont know until I try them.
Also I wont be using a cabrio,so less weight to handicap me,but will that help or will it cause more problems getting the power down?
Reply #91 on:
July 11, 2012, 12:00:23 pm »
Quote from: richie on July 11, 2012, 11:52:52 am
Quote from: JHU on July 11, 2012, 10:07:00 am
Cool thread Mr Webb.
Doping 10's on the cheap... And drive home. The triangle of speed sais no. But can it be done? ... I think that depends on what YOU mean by cheap.
Most things in life ends up costing more in the long run when you have the needed money up front.
Maybe supercharged engines dont follow this logic?
But if someone think they might, what base engine would give tens most reliable?
I know how much it will cost,as that figure is all I have to spend
so i may have to do a little wheeling and dealing to get there,and yes cheap is a relative word,I think I could run 12s for less than 5000pounds,but it would be a very light car and not suitable to run 10s, carefull planning should help achieve this but we will see.
My ultimate aim will be to leave the race car at home next august and drive to norway,while I am there on holiday I will see if there is any local racing,if there is they maybe go to the track and see if I can do it there,any ideas?
maybe that is not achivable in the time scale but I will try and then who knows
10s debut on SCC2013?
Reply #92 on:
July 11, 2012, 12:06:53 pm »
Quote from: karl h on July 11, 2012, 11:09:14 am
this will definitely be a thread to follow
a cheap busbox conversion (stock ratios/no nosecone swap) would be very interesting
just for the fun of it, try a couple of runs without the bottle/slicks/stinger (real street trim), should do a 12???
i really like wbx conversions and have done a few, but if you dont take advantage of the bigger bore (at least 97), its better to stick to an aluminum type 1 case, heads will be much easier to get
Karl
thats my thought as well,I dont think a 4inch engine will be economically viable,the heads alone cost to much and are so difficult to get in common castings[comp elims for example]
As i am not trying to build the best N/A engine it isnt so important,the 94bore stuff will do what I want,and keeps it more in line with what most people can relate to with there own cars.
I will proberly use a mag case as well as I know it up to the task.
I will do a couple of passes as I drove it to the track to get the car set up right before trying to run a good number
Reply #93 on:
July 11, 2012, 12:08:38 pm »
Quote from: Erlend / bug66 on July 11, 2012, 12:00:23 pm
Testing on the autobarn on the way,sounds like fun
Reply #94 on:
July 11, 2012, 12:11:56 pm »
Quote from: richie on July 11, 2012, 12:08:38 pm
Kudos if you frive it all the way, do a couple of 10s passes and drive it home again!
You should add a stereo for the trip
Chris bugster
Reply #95 on:
July 11, 2012, 12:21:19 pm »
Hi Richie
Does it have to be a Bug? A good Bug is expensive. How about a Fiat 126? They are cheap here, about $100 and light, ours weighs 650kg with full cage and IRS box and Ali cased stroker. It could easily go much lighter.
BTW- Richie, do you still have my Berg shifter in your Cabrio? Any chance of getting it back?
11.2@124mph
Reply #96 on:
July 11, 2012, 12:35:20 pm »
Quote from: Chris bugster on July 11, 2012, 12:21:19 pm
Hi Richie
Yes it has to be a VW
,and not sure what shifter you are talking about,the one in the cabrio has been in there since 96 when I bought it from bergs way before I knew any of you?
Chris bugster
Reply #97 on:
July 11, 2012, 13:04:16 pm »
Sorry for the misunderstanding, Richie. After I rolled my 1303, Max asked me if ''Richie'' could borrow my shifter and I thought he meant you, but it must have been someone else. Good luck with the project.
11.2@124mph
Reply #98 on:
July 11, 2012, 13:14:53 pm »
Quote from: Chris bugster on July 11, 2012, 13:04:16 pm
No idea Chris,I only know the story of your 1303
,nothing more
Wunder Wim
Reply #99 on:
July 11, 2012, 19:20:02 pm »
Hi Richie
maybe this is what you are looking for...
http://www.thesamba.com/vw/classifieds/detail.php?id=1246938
Wim
Reply #100 on:
July 11, 2012, 19:34:28 pm »
Thanks I did notice that today,but the ratios are to short to run 10s with the mph needed,shame as its a good price
Airspeed
Reply #101 on:
July 11, 2012, 20:13:41 pm »
What 60ft, 1/8 time and 1/4 mph do you think you need Richie?
Reply #102 on:
July 11, 2012, 21:43:11 pm »
Walter
From memory the old cabs best nitrous 60ft was 1.48[only once though,the 10s were 1.50s] 6.96 1/8 mile and 10.88@125mph in 2003,only just realised it will be 10s years next year since I did it
I think I can get it to 60ft mid 1.40s now so hopefully 6.70s 1/8 and 10.?? 1/4[dont want to jinx myslef with those goals yet
Reply #103 on:
July 12, 2012, 09:06:50 am »
Quote from: Airspeed on July 11, 2012, 20:13:41 pm
Now were talking! Only a car with lots of hp can somewhat make up for a poor start. Look at the white Bello (spell check) Porsche 911 with 1000+ hp as a example, low 10's and high 9's with VERY soft launches. Besides, a nitrous car do have its advantage in the start and will never have the top end speed of a turbo monster.
1.40 - 1.45 should be possible without spending a fortune.
-BB-
Reply #104 on:
July 12, 2012, 09:18:39 am »
Very cool thread! Will be following this to help my own bug getting faster
So Beetlebug what does it take to get such 60ft times? Apart from being a good driver
Reply #105 on:
July 12, 2012, 10:07:19 am »
Quote from: BeetleBug on July 12, 2012, 09:06:50 am
-BB-
2 stages? i havent tried it but its something I will consider later on,and I agree those 60fts should be possible,mabye quicker with devolpment,there is a Nitrous pan car running low 1.30s over here,and I am sure it went 1.30s before the bars were added,getting the weight down by about 95kg or 200lbs from th eold cab should really help
Reply #106 on:
July 12, 2012, 10:08:35 am »
Quote from: Jesse/DVK on July 12, 2012, 09:18:39 am
Apart from luck you need a good strip, two good tires, the correct tire pressure, just enough clutch, a well planed rear suspension and enough hp.
BB
henk
Reply #107 on:
July 12, 2012, 11:30:06 am »
i think this is everybody's new favorite topic.
looking forward to the end result.
henk!!!
Reply #108 on:
July 12, 2012, 11:54:42 am »
Quote from: henk on July 12, 2012, 11:30:06 am
henk!!!
Agree! Who cares about expensive, vintage shit, show'n shine and old car clubs when you can drive 10's
Reply #109 on:
July 12, 2012, 12:09:29 pm »
I think I found the right donor car,will be looking at it this weekend,if its as described then I will be dragging it home soon
Shane Noone
Reply #110 on:
July 12, 2012, 16:42:31 pm »
Hi Richie,
Once you have worked out what it takes, for fecks sake let me know as no matter what I do or how much I spend. I'm still stuck in the 12's darn it !!!!
Cheers,
Shane.
dannyboy
Reply #111 on:
July 12, 2012, 17:57:06 pm »
Quote from: Shane Noone on July 12, 2012, 16:42:31 pm
Hi Richie,
Cheers,
Shane.
thats your own silly fault
TAKE OFF THE BELT AND ADD NITROUS
8.77@156.8mph
O/FF 60
Reply #112 on:
July 12, 2012, 18:41:40 pm »
Quote from: dannyboy on July 12, 2012, 17:57:06 pm
thats your own silly fault for listening to Danny
TAKE OFF THE BELT AND ADD LOTS OF NITROUS
Fixed it for you
Shane I do plan on sharing my findings,however good or bad they are, and your car is a perfect example of one that could see huge improvements with gas
Now while this isnt totally apples to apples comparission as 3rd and 4th gear ratio were changed between,
but my cabrio ran bext of 13.27 N/A against the 10.88 with nitrous,is that a big enough improvement for you?
Reply #113 on:
July 12, 2012, 19:08:14 pm »
I'm looking forward to this build,
Wishing my Wiseco's were nitrous versions now
Out of interest what were the gear ratios in the cab with the nitrous motor?
dannyboy
Reply #114 on:
July 12, 2012, 19:24:22 pm »
my car ran 11.8 n/a, 30 shot of nitrous 11.45 so it does make massive improvements for a small amount of money cant wait to see what another 30 hp of gas does this weekend
8.77@156.8mph
O/FF 60
Shane Noone
Reply #115 on:
July 12, 2012, 19:47:52 pm »
Quote from: richie on July 12, 2012, 18:41:40 pm
Fixed it for you
I remember how frustrated you were when your cab with the JMR 2332 was only making 13.2's but didn't you re-work that 2332 and as you say tailored the gear ratios's to better suit ...? Surely your saying you took a 190 - 200 hp motor that ran 13.2 changed the gear ratios added a typical 50-60 shot of NOS and bingo your in the 10.8's
If that is what your saying then freakin awesome and pass me the blue bottle now
Danny, will you quit with the no belt and NOS already
I will do one day mate
Seriously back to Richie's original quest but with a slight twist - how much N/A bhp and Torque does it take to propel a factory weight Beetle into the 11's and the 10's with conventional T1 transmission allowing a close 3rd and 4th of any combination and a choice from 4.37 / 4.12 / 3.88 factory spec final drives.....
Cheers,
Shane.
Reply #116 on:
July 12, 2012, 20:06:21 pm »
You need to read back abit for the nitrous shot needed
your way off
Seriously the original 2332 was way to slow for me,never even went near that 13.27,so I bought a kit and it went high 12s,then with a few tweeks 12.05 best[remembr the 5th gear episode against the bentley? ] then we made a couple of changes to the cam and heads and went 11.5 still with the old gearbox,at USC that year I broke the stock 1st gear when I messed up with a sportsman tree against the pro tree I was expecting,we changed the ratios and put a mainshaft in it,next meeting 11.12 best,just from the ratio changes,then next meet into the 10s
Thats a simplified version
As to how much hp needed to run 11s n/a and 10s n/a,there are so many variables I couldnt accurately answer,I think you need about 300hp to run 10s off the top of my head,but thats only a guesstimate,about 210 to run 11s,but the ratios would be a pig on the street
Danny can you refresh my memory as to how much your car weighs for comparission?
Reply #117 on:
July 12, 2012, 20:09:06 pm »
Quote from: leec on July 12, 2012, 19:08:14 pm
Lee I can only remember 1st and 4th 3.78 and 1.12 with a 3.88 R&P,I would guess that it was around a 2.20 2nd and 1.50 3rd
and I ran about 80hp on mahles so the wisecos will take a bit
dannyboy
Reply #118 on:
July 12, 2012, 20:12:05 pm »
760kgs with driver 690 without
shane you know im only messing with you
8.77@156.8mph
O/FF 60
Reply #119 on:
July 12, 2012, 20:22:16 pm »
Quote from: dannyboy on July 12, 2012, 19:24:22 pm
11.8@1672lbs = 201hp
11.45@1672lbs=220hp
so 250hp=10.97@122.08mph
Realistically you will proberly need another 15hp to actually see the 10s,but your gearbox changes may make a difference as well
Shane you got weight and hp for your car? I will see what the magic ball says you need to add for 10s
5
6
36
