September 08, 2024, 01:45:10 am
Dom Smith
How much money to run 10s in a street car?now with part2, The evolution to turbo
33
34
Topic: How much money to run 10s in a street car?now with part2, The evolution to turbo (Read 508097 times)
Chip
Re: How much money to run 10s in a street car?now with part2, The evolution to turbo
Reply #990 on:
July 12, 2024, 06:40:17 am »
Quote from: richie on July 10, 2024, 08:07:47 am
Quote from: Chip on July 10, 2024, 03:50:34 am
It looks like you ended up removing the package tray on this one. Did you end up boxing up to the rear window more or less? I'd love to do a similar setup to my 60 one of these days. I'm excited to see this build continue to mature!
I just clearanced it enough for turbo to fit up high enough and for air filter hose to turbo, then ally panelled over that, finally made a carbon rear seat to cover it all
I like it!
Last Edit: July 15, 2024, 16:55:16 pm by Chip
BossHogg76
Reply #991 on:
July 15, 2024, 08:35:30 am »
That looks pretty damn epic. I think i'm going to copy the carbon fibre back panelling....up until i see the price for the sheets, then it'll be plywood and carpet
Reply #992 on:
July 15, 2024, 21:36:42 pm »
Needed a decent fuel system, luckily I ran big enough fuel lines through car 1st time so main upgrade was the pump, went with this from fuelab, next was converting car to hydraulic clutch, fitting a master cylinder is not easy on a RHD car, its a bit tight in there!!!
Steve D.
Reply #993 on:
July 16, 2024, 02:56:25 am »
Nice pump!
Über Alles
10.77 avg. on pump fuel.
238I
Reply #994 on:
July 16, 2024, 20:57:38 pm »
Quote from: Steve D. on July 16, 2024, 02:56:25 am
Nice pump!
Shame it wasn't big enough, but that's getting way ahead of where i got to with updates
Steve D.
Reply #995 on:
July 17, 2024, 04:51:30 am »
Quote from: richie on July 16, 2024, 20:57:38 pm
Nice pump!
I told you not to buy the small one. Does that mean I can have my spare back?
Über Alles
238I
Reply #996 on:
July 17, 2024, 08:10:28 am »
Quote from: Steve D. on July 17, 2024, 04:51:30 am
Nice pump!
Don't remember that conversation, this was way before you ran out of pump on yours, this is pump you now got and supposed to send to John or Lester in february
ibg
Reply #997 on:
July 17, 2024, 10:26:56 am »
Richie, I'm enjoying this thread. Do you have a shot of the pedal side of the clutch set up. I've done one on the left side by extending the clutch shaft through and out the left side of the tunnel, but yours looks very neat. Also, which master cylinder?
Reply #998 on:
July 18, 2024, 07:14:37 am »
Quote from: ibg on July 17, 2024, 10:26:56 am
Its a 19mm wilwood master cylinder, I don't have a decent pic of it finished, this is pic showing master mounted from inside and extension rod i made
ibg
Reply #999 on:
July 18, 2024, 10:52:57 am »
that is nice with the little Heim to let find it's own centre
thank you for sharing
Reply #1000 on:
July 19, 2024, 09:12:08 am »
Quote from: ibg on July 18, 2024, 10:52:57 am
No problem, your welcome
Reply #1001 on:
July 19, 2024, 09:21:00 am »
While this was going on I got the cage checked and certed for 8.50, before it was only tagged to 10.0 as I figured it wouldn't go quicker than that with the nitrous engine in it.
Upped the fuel outlet on tank to be sure it would be big enough whatever i tried later on
Also made some molds of 2 different rear air deflectors to try and then made them from carbon of course
and added some shock sensors to measure the effects of them
Reply #1002 on:
July 21, 2024, 21:42:37 pm »
Perfect car for a drag and drive competition
Reply #1003 on:
July 25, 2024, 11:12:31 am »
Quote from: j-f on July 21, 2024, 21:42:37 pm
That's the plan
I had finished all the mock up stuff needed at this point so could clean and assemble engine ready to go back in
Reply #1004 on:
July 29, 2024, 16:38:35 pm »
just out of curiosity, did you change the cam? I presume you did, one better suited for a turbo, or is this not being done anymore? and are that pauter rods or the newer CB?
Reply #1005 on:
July 29, 2024, 20:27:19 pm »
Quote from: nicolas on July 29, 2024, 16:38:35 pm
This is a completely different engine, i sold the other complete with gearbox and all the nitrous set up as well
Yes they are pauter rods, i haven't tried the new cb rods yet
Reply #1006 on:
August 03, 2024, 13:47:49 pm »
Never fitted these ally bearing retainers 1st time round so thought it was about time, also used some Ti hub nuts but they really aren't worth the ££££ - Grams saved
Last Edit: August 05, 2024, 21:29:36 pm by richie
33
34
