January 07, 2025, 08:52:15 am
351324 Posts in 28676 Topics by 6862 Members
Latest Member: Bwiley
| | |-+  How much money to run 10s in a street car?now with part2, The evolution to turbo
Pages: 1 ... 34 35 [36] Print
Author Topic: How much money to run 10s in a street car?now with part2, The evolution to turbo  (Read 532319 times)
« Reply #1050 on: December 25, 2024, 12:17:36 pm »
three: there may have been some bias in the testing done to prove dtm is best  Wink
Surely not... Grin
 Shocked Cheesy  Yep its possible!!
« Reply #1051 on: December 25, 2024, 12:57:50 pm »
So once i was happy with fit of fiberglass shroud I started to figure out how to mount the fan/alternator & ring assemble, then on to the idler pulleys and mounts and this was what I 1st came up with Smiley
« Reply #1052 on: December 25, 2024, 15:28:58 pm »
A DTM from Jack Raby is not enough for your purpose?
He did some extensive testing on the VW cooling.
No, for several reasons,
one: all the testing i have read about[no idea how accurate it is]  shows it cools evenly over all cylinders but as it uses a regular fan its still limited on how much air it moves at any given rpm, i have a tall 4th gear so fan speed is quite slow, using a 911 fan which moves double the air a wide type 1 fan does at an given rpm should make a huge difference Smiley
two: the dtm set up takes even more room in engine bay than type 1 does so harder to fit everything in, and worse work on it as well  Shocked
Thanks for your explainations  Smiley
Hard to tell what's technically good, versus a good marketing nowadays.
