October 13, 2026, 04:38:14 am
| | |-+  best aspirated cam????
Author Topic: best aspirated cam????  (Read 17776 times)
stussyrich
« on: July 15, 2012, 22:27:24 pm »
Ok guys whats your opinions on the best cam for an aspirated motor.
some specs.
2387
scat case with centre thrust.
86 scat flange crank
5.5 rods
wiseco teflon coated pistons with valve pockets.
tool steel lifters
ultra wedgeport heads 47x38 titanium valves Ls1 springs 33cc chambers.
berg 1.4 rockers
51.5 italians
berg 1" 7/8 stepped header
around 13.5 compression..
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: July 15, 2012, 22:34:48 pm »
Ask JPM!
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
dannyboy
« Reply #2 on: July 15, 2012, 22:39:49 pm »
/\/\/\/\/\/\ thats where my next cam will come from only heard good things  Cool
8.77@156.8mph
O/FF 60
« Reply #3 on: July 16, 2012, 08:48:45 am »
FK48 on 108 lobe centers or FK89 for less maintenance on valve train
cheers richie
jamiep_jamiep
« Reply #4 on: July 16, 2012, 15:55:29 pm »
I'd stick a 110 in there rich Smiley hahaha
how else am I going to get in front of you?!
 Grin
Fast Bug
« Reply #5 on: July 16, 2012, 19:13:23 pm »
JPM Raptor and alu pushrods Wink
« Last Edit: July 16, 2012, 19:17:42 pm by Fast Bug » Logged
JS
« Reply #6 on: July 17, 2012, 22:46:41 pm »
Ask JPM!
Nope, he would get the correct answer - not an opinion.
Signature.
Erlend / bug66
Global Moderator
SCC Event
« Reply #7 on: July 17, 2012, 22:54:37 pm »
My opinion is to ask JPM  Wink
The '67:
The '59:
Not yet..
stussyrich
« Reply #8 on: July 17, 2012, 23:48:19 pm »
this was a suggestion..  custom grind   .613 lift 320 duration on a 105 lobe center..
« Reply #9 on: July 18, 2012, 02:57:07 am »
I was under the impression that the 86c was the next best thing behind the Raptor cams?
SuperTrigger
« Reply #10 on: July 18, 2012, 10:42:08 am »
FK46. Smiley
Almost same engine that you have exept lower compression (11.x:1) and 44 intake valves it made 195whp@6700rpm and 230NM (234hp/266Nm at engine).
-Puide-
« Reply #11 on: July 18, 2012, 13:31:32 pm »
Whats "best"? ...more power or long life/silent valve train?  Many cams are designed the modern way, but usually the power is lacking...  JPM's cams have both...
stussyrich
« Reply #12 on: July 18, 2012, 13:56:53 pm »
should have said it's for drag only so not bothered about long life or quiet valve train.
The lifter bores have bronze bushings and i'll be using tool steel lifters..
« Reply #13 on: July 18, 2012, 14:50:52 pm »
Don't forget SINGLE springs!  Wink
TxT
« Reply #14 on: July 18, 2012, 18:20:22 pm »
The 86C is a killer cam. But in an engine like that with 13+ - 1 CR better choices can be made. You dont build an engine like that an want to drive it on the street much...
IŽd also say FK89 or the new 2290 (I think) from CB. if you are ready to step up to a Ratptor, that would most likely give you most HP, and definitely the lesser need for valve spring tension.
« Reply #15 on: July 19, 2012, 02:02:53 am »
Thanks for the clarification, Torben. I've got a 2332 longblock that I hope to stab that cam in someday...
Shag55
Shag Leone, SL-1racing
« Reply #16 on: July 19, 2012, 04:12:16 am »
Re: best aspirated cam
I have a xr328 on a 106 and TP tool steel lifters. It was made for a Super Stock motor. It was on a 106 to help get out of the hole with such a big cam on a smaller motor. 240-250hp.
With a big motor say 280 really no need for a tight lobe center.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
« Reply #17 on: August 07, 2012, 22:39:00 pm »
I had an 86C then went to the dark side and now have JPM
« Reply #18 on: August 08, 2012, 01:40:35 am »
Me too. ...and single springs from Crower.
bedjo78
« Reply #19 on: August 08, 2012, 03:14:34 am »
in tropical weather fk47 with 1:5 rocker  worked well.
« Reply #20 on: August 08, 2012, 07:37:09 am »
Did you ask your engine case?
Erlend / bug66
Global Moderator
SCC Event
« Reply #21 on: August 08, 2012, 07:45:30 am »
 Cheesy
I've seen a engine block with a split-cam with FK4x on the lobes.. Lifter bores did not look to happy
The '67:
The '59:
Not yet..
« Reply #22 on: August 08, 2012, 08:00:51 am »
I think you mean you stepped out of the dark ages.
bedjo78
« Reply #23 on: August 08, 2012, 08:29:51 am »
 Cheesy
the lifter bores sleeved . the power come early and pull strong up 7500 rpm
« Reply #24 on: August 08, 2012, 10:34:15 am »
I know, I used one myselves in a alu case but luckily I got it out before it did any damages.
