October 01, 2026, 02:29:29 am
my gulf blau, 61'er, street racer project...
Topic: my gulf blau, 61'er, street racer project... (Read 12876 times)
magic
July 17, 2012, 00:42:16 am »
I,and a few good friends!! started making me a 61'er ....Ok, for some time now...
( I do not ride the same day I saddle the horse!!)
It will get all the small changes and details that I've been dreaming about in my previous two beetles... This time it will be a "cal look" ... So I should really learn to control myself!
And only make small discrete alterations .... ie, I have moved the gear lever 6cm. backwards. (I've always run the driver's seat right up against the back seat) So I am excited to be able to get it in 1st and 3rd.! .
. (I run with H harnesses)
Right now I'm by raising the engine and gearbox 1" (or more exactly 29mm.) With the help of the old trick, using a bus-gearbox-nose.
Have just raised the luggage shelf and all the other things (I do not know the English words .. sorry!) around the engine .... (I REALLY need to learn how to put pictures up in here! Grrrr..) Well, now I have a question..... Have just heard rumors that I'm going to change the length of the suspension arm ... or just the sluts for the axle bearing housing ...
But by how much?... which way?.... is it something you can figure out in relation to the 29mm. Lift? .... What?? ... Help!!!
Sincerely. mads.
Last Edit: July 21, 2012, 22:52:16 pm by magic
magic
Re: my gulf blau, 61'er, street racer project...
July 21, 2012, 20:13:55 pm »
this will just be my first try to post pictures
Last Edit: July 21, 2012, 20:40:31 pm by magic
magic
July 21, 2012, 20:55:57 pm »
Yes it works!!
magic
July 21, 2012, 21:15:02 pm »
One more.
( this is the tranny raise)
Last Edit: July 21, 2012, 22:37:00 pm by magic
magic
July 22, 2012, 19:35:52 pm »
I saw it in an ad, far up north in sweden ... with sun burned paint, lowered to the ground and with Rader weels. for 9000skr. (something like $ 1,290) And I suddenly saw a clear picture of how it would look like with a set of centerline 5 "and Bridgestone 165/65 15 out front. And centerline convo pro 7" with. Hoosier 245/60 15 at the rear. So, a day for now a few years ago, a friend and I took the ferry to our brother country Sweden, with an auto transporter, and took a LONG ride up into the snowy north of Sweden (perhaps you Swedes now laugh and tell me that it really was only in the middle of sweden) But it was some 850km. from Varberg.... and ALL the young people were out driving on their snow scooters!!!
Cold... and Cool ride Allan
The first thing I did when I got home was to sell of the Rader's ... And buying the said centerline wheels! But to hell ... I could only find convo pro's in star cut
..... But one day.....
This is from when I had just bought it. Here without a motor. hence the "funny" stance ...
Last Edit: July 22, 2012, 20:03:34 pm by magic
magic
July 27, 2012, 22:29:55 pm »
Have just used this book when I had to shim the link pin. Have only borrowed it from a friend. But it is just so cool and fun.
I wonder if you can still buy it? and where...
Last Edit: July 27, 2012, 22:31:32 pm by magic
magic
July 27, 2012, 22:33:59 pm »
(It is just made for people like me)
July 29, 2012, 10:59:55 am »
You can still get it, think I got mine off amazon
magic
July 29, 2012, 16:39:28 pm »
Quote from: andy198712 on July 29, 2012, 10:59:55 am
Thank you Andy! Of course, Amazon. why didn't I think of that.....
magic
August 03, 2012, 14:40:41 pm »
. Hmm...problems with the pictures again....
Last Edit: August 03, 2012, 15:02:38 pm by magic
magic
August 04, 2012, 11:31:25 am »
Here we go again!!!!
magic
August 04, 2012, 13:58:12 pm »
I don't know if you can see it on the last picture, but I've shortened the axle tubes ..... NOT the axel! ie. I took a set of long and shortened it to the length of the short ones, then I cut a similar piece out of the torsion tube (actually not me, I helped a friend who is a pro welder .... do not dare to mingle with this parts.. I have to drive the car myself
) ... This creates more space, and make it possible to run wider tires AND original width fender!
Last Edit: August 04, 2012, 18:29:45 pm by magic
magic
August 04, 2012, 17:56:44 pm »
if you look at the background in this picture, you can see that I've moved the bracket from the outside position to the inside, to follow the narrowed torsion-tube tower.
Or, I hope you can.....
Last Edit: August 04, 2012, 17:59:44 pm by magic
magic
August 08, 2012, 14:38:05 pm »
although it's all just a test set .... I can't wait!!
magic
August 13, 2012, 14:50:54 pm »
more testing.... Unfortunately, the wheels do not sit where I want them
... So, back to the drawing bored..... again
