October 13, 2026, 11:20:36 am
| | |-+  DDS power pulley belt size
Author Topic: DDS power pulley belt size  (Read 6139 times)
Fritter
« on: July 21, 2012, 02:35:20 am »
I have a few DDS power pulleys with the 3 "kidney" shaped holes in them.  I want to run one of these babies on my '64 but I don't know the belt size needed.  Anyone know?
I assume it's a smaller size than the belt I currently have on there with my Santana power pulley.
Mike F.
'64 Indigo Blue sunroof Bug
andy198712
« Reply #1 on: July 21, 2012, 17:23:49 pm »
What's the pulley dia?
Rick Sadler
« Reply #2 on: July 21, 2012, 18:16:09 pm »
9.5 x 850 for the power pulley
« Reply #3 on: July 21, 2012, 20:01:57 pm »
A DDS pulley is smaller than a standard power pulley.
Cheesepanzer
« Reply #4 on: July 21, 2012, 20:44:27 pm »
You could try the old "rope trick" to get an approximate size and then try to get it matched up at your favorite parts place.
63 Type 2 Single Cab
Cornpanzers
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #5 on: July 21, 2012, 21:58:38 pm »
You also could listen to Rick who knows whats up.
Fritter
« Reply #6 on: July 23, 2012, 18:38:07 pm »
Thanks for the answers, I'll check out the 9.5 x 850 with my teeny tiny Deano crank pulley.  This pulley should add at least 50 horsepower according to my calculations.  Cheesy
Mike F.
Fritter
« Reply #7 on: July 24, 2012, 15:07:03 pm »
Update:  I don't think the 9.5x850 is the right size for the smaller Deano pulley.  9.5x850 is the size I am running now with my Santana power pulley.
I think I'll try the rope trick.   Grin
Mike F.
Cheesepanzer
« Reply #8 on: July 26, 2012, 02:29:11 am »
 Grin
Cornpanzers
« Reply #9 on: July 26, 2012, 08:29:14 am »
The DDS pulley needs a shorter belt than a power pulley.
I had my DDS pulley machined to make the groove wider to take a wider (stronger) belt.  The belt I use is a Ford JB-331.  This belt is 33&1/8" long, or about 840mm.
Tobi/DFL
« Reply #10 on: July 26, 2012, 08:54:20 am »
Hi!
The belt I used was 835mm long.
Tobi
