October 13, 2026, 19:50:03 pm
| |-+  For sale!
| | |-+  Re: drag for sale SOLD
Author Topic: Re: drag for sale SOLD  (Read 7568 times)
kglolo
« on: July 23, 2012, 11:17:24 am »
rollcage Ron lumus Racing,
engine 2442 cc 260 cv, terminator 62,cylinder heads autocraft with 50 X 44 ,
shifter JCL,
Price: 21000,00 €
For more: olddreamcar@yahoo.fr
Car weight : 550 Kg
Thanks : Laurent
Uploaded with ImageShack.us
« Last Edit: September 25, 2012, 09:56:13 am by kglolo » Logged
kglolo
« Reply #1 on: July 30, 2012, 09:14:50 am »
new and last price 20000,00 €
« Last Edit: July 30, 2012, 14:44:32 pm by kglolo » Logged
kglolo
« Reply #2 on: August 02, 2012, 19:27:44 pm »
More info,
The powerplant in this Pro Stocker is a stout 2442 cc based on the type 1 VW configuration.
The center of attention in this engine is a Bugpack88mm flanged cranked with 411 main bearing that is connected to a set
of Pauter 5.700-inch Chevy rods and 94mm Wiseco pistons inside Century cylinders.
Cam is a tried-and-true FK89 from Engle, and the rocker arm assemblies are 1.4:1 Pauters.
Pushrods are Gene Berg inside CSP tubes, while some of the other Berg goodies are straight-cut cam gears, 30mm full flow oil pump,
4-quart sump and lifters.
Ported and polished Performance Technology built heads house50mm intakes and 39mm exhaust valves, with K-motion valve spring and titanuim retainers.
Air and fuen distribution is handled by a set of Geers 62mm Terminator carbs with 50mm venturis bolted to a set of Auto-craft intake manifolds that have been heavily modified.
Engine was built with 13.5.1 compression
Distributor is also a GB product, a S4 stinger setups, but this one utilizes a JayCee crank trigger and MSD 7 AL box, coil, 2-step and rev-control to help set off the spark.
Type 1 gearbox with aluminuim JayCee spool
5-inch shorter SAW axles
32-inch ladder bars
Summit racing shocks
Bugpack 3-puck disc and Kennedy 2600 pound pressure plate
Rear braking is controlled by a set of Strange and Wilwood combo 4-piston brakes and stage breake.
Rear wheels are also Ercos, but with a set of Mickey Thompson 8.5-inch slicks
kglolo
« Reply #3 on: August 04, 2012, 12:35:01 pm »
Nobody for a good dragster ready to roll.  Huh
Possible without engine .
thanks Laurent
kglolo
« Reply #4 on: August 06, 2012, 11:48:13 am »
new new new price , 19000,00 €  Cry
kglolo
« Reply #5 on: August 09, 2012, 21:37:46 pm »
Re Re up
without engine, 14000,00 €
kglolo
« Reply #6 on: September 04, 2012, 10:58:05 am »
hello, last price,
18000,000000000000000000000000000000000000 €€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€€
« Last Edit: September 08, 2012, 08:29:29 am by kglolo » Logged
kglolo
« Reply #7 on: September 08, 2012, 08:30:10 am »
17.000,00   Cry
kglolo
« Reply #8 on: September 25, 2012, 09:55:38 am »
SOLD
kglolo
« Reply #9 on: September 25, 2012, 09:55:56 am »
shifter JCL,
Price: 21000,00 €
Car weight : 550 Kg
Thanks : Laurent
