September 14, 2026, 14:00:29 pm
Bad Habit
Pauter block cooling options
Topic: Pauter block cooling options (Read 34758 times)
Fast54
Re: Pauter block cooling options
Reply #30 on:
July 29, 2012, 22:47:38 pm »
This is one way, my own aluminum design.
Of course this is a low comp.ratio turbo motor, so it runs cooler than an aspirated. About 125C on the road.
/Hεkan
Andy Sykes
Reply #31 on:
July 29, 2012, 22:56:29 pm »
That's is very nice
Cheers andy
dannyboy
Reply #32 on:
July 29, 2012, 23:31:35 pm »
bloody hell that thing looks like its come out of the space shuttle
8.77@156.8mph
O/FF 60
Andy Sykes
Reply #33 on:
July 30, 2012, 20:26:06 pm »
Nice chat with mario
80 mm stroke
108 bore
6,2 rod
The rest will come later
Airspeed
Reply #34 on:
July 30, 2012, 20:54:44 pm »
Cool! that 6.2 rod with the 80mm stroke will make for a very nice rod-ratio (1.97)!
Andy Sykes
Reply #35 on:
July 30, 2012, 22:18:57 pm »
Oh running meth
So my next load of questions
Apart from not liking aluminium, burning with no flame or smoke And needing lots of flow
What else ?
Reply #36 on:
July 31, 2012, 09:06:33 am »
Quote from: fast65 on July 30, 2012, 22:18:57 pm
Oh running meth
What else ?
Don't drink it (even though you can), make sure all fumes are vented so you don't get it in the cockpit, prolonged exposure can cause health problems.
Martin
Cash Converter....
Reply #37 on:
July 31, 2012, 10:39:40 am »
Oh running meth
What else ?
Richie / Jim Smith are may be the best to answer this as they use it more than anyone else on here.
I used to run it, in woper. my procedures went like this..
first fire in the morning.. use petrol! to get a little heat into the heads.
then turn on the meth, and off it goes...
Go race
At the end of the weekend, drain the tank put some petrol in it (load up your gas map
) then run it to clear out the injectors and lines.
some people keep meth in the system , they just top it right up, but persoanly im like to get it out of there..
the meth you take out keep seperate from the "new meth" as it would have already started taking on water (you can get a hydromiter to see how much water is in it to make sure).
buy your meth in small containers and dont leave it open to the air, as its takes on water from the air then it just wont make the power
Dont buy the cheap "printer cleaning Alki" as the quality is not up to spec.
dont use fuel pumps that are submurged (aeromotive pro pumps ect) as the electrolisis effect just eats the pumps away, stick to a pump rated for the HP and fuel. I personaly use Weldon pumps.
as there motor is seperate from the fuel
I never suffered from milky oil as i got the oil temps up past 90 oC and the water vapoured off keeping the oil nice.
be prepaired to buy loads of it as you need twice as much! lol
and the most important bit..... Have fun!
just my take on it...
Martin
Martin
www.taylormachine.co.uk
OFF/500
Andy Sykes
Reply #38 on:
July 31, 2012, 18:08:12 pm »
Thanks Martin
the spec so far
1 90-1000- F/C Pauter Big Block for Chrysler or Ford mains
Includes: dry sump pan, top and front covers, flywheel plate, cam gears, dist clamp and misc fasteners
1 63-394 80mm Pauter billet crank / flanged end
1set 50-660 4340 chrome moly billet rods,( 6.200/turbo )
1kit 86-030 roller cam and lifters (profile to be determined)
1kit 40-619 modular bore kit (4.250 pistons, cyls, rings, pins with buttons)
1pr 90-200-T Pauter Super Pro heads stage 2 57m x 43m titanium valves and retainers
PAC springs , polished, ccd , stainless orings and assy
1pr 90-340 Vave covers , Pauter SP heads
1set 90-300 exhaust flanges for customer header system
1set 90-301 copper exhaust gaskets
1set 90-1012 chrome moly head stud kit w/ nuts & washers
1set 81-2?0 1.4, 1.5 or 1.6 Super Pro billet roller rocker kit
1set 80-099 Super Pro pushrod tubes
1set 80-070 3/8 or 7/16 dbl tapered HT Chrome moly pushrods to length
1set 40-413 copper head gaskets for modular bore kit (head to cyl interface)
1kit xxxxx set, rod / main / cam bearings, all seals
1 30-511 flanged-end flywheel w/ McLeod 2-disc clutch assembly
1 94-400 4-stage Center-Flo oil pump, VW drive, no fuel pump drive
cheers andy
Reply #39 on:
July 31, 2012, 18:28:41 pm »
Wow! A typical overthetop old school US engine. Built like a tank and should be perfect for your car and trailer.
Quote from: fast65 on July 31, 2012, 18:08:12 pm
Thanks Martin
the spec so far
cheers andy
Andy Sykes
Reply #40 on:
July 31, 2012, 18:52:57 pm »
It's the way I roll lol tbh I couldnt find a way to get what I was looking much less than this and not realy proven I don't know enough about engines to make that call so somebody had to
Cheers andy
Last Edit: July 31, 2012, 19:24:54 pm by fast65
Jyrki
8.88 & 251
Reply #41 on:
July 31, 2012, 21:53:42 pm »
Quote from: Airspeed on July 29, 2012, 19:28:17 pm
Jyki, very stealth looking indeed!
Why didn't you keep it?
It was pretty fun the first season (11.53/187 in a full-weight street car in full street trim; nice torque, shift point at 6300rpm), but the following year on my first pass, maybe 5 seconds into the run I realized that for drag racing it's just way too slow (ie boring), and drag racing is my thing. Sold the car w/o engine and focused again on turbos. True story
Jyrki
Shag55
Shag Leone, SL-1racing
Reply #42 on:
August 01, 2012, 17:59:05 pm »
Why not just turbo that car Jyrki?
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
volkskris
Reply #43 on:
August 01, 2012, 19:44:03 pm »
Can you share more specs of that engine please Jyrki?
Jyrki
8.88 & 251
Reply #44 on:
August 01, 2012, 21:39:15 pm »
I bought the engine as non-used long block in 2007 (or 2006??); it had been in a wooden crate since late 90s. The engine was in my street '55 beetle in 2008 with 62mm carbs and in 2009 with TB's and EFI. 94 stroke x 4.25" bore, 57x43 heads, roller cam, 11.0 and later 11.8:1 compression, home-built 4-2-1 header. Ran mid 11s in a 900kg street car so maybe 250-260hp / 6000rpm? Should have made more..
With turbo in that car it would have been lethal without making major changes, and I kinda already had one car that was already cut to fit turbo and everything involved. So 2010-2011 I focused on running my good old '65 street turbo car. It was fun, but after racing the same car for a long long time it was time to move on, so now the Pauter engine sits in a new project car, with shorter rods to lower compression to 8:1 and a smallish turbo. Not fired yet.
Jyrki
