July 23, 2026, 19:14:25 pm
352243 Posts in 28935 Topics by 6923 Members
Latest Member: Lotus67
| | |-+  broken fanbelt
Author Topic: broken fanbelt  (Read 5404 times)
« on: August 01, 2012, 12:29:34 pm »
Hello,
My cousin's motor seems to be a belt eater!
i think he already bought like 10 new belts...
they either break or they jump off...
the pulleys are aligned well but still problems...
You guys know what could be the cause?
its a normal size scat pulley ..
cheers, P
Erlend / bug66
Global Moderator
SCC Event
« Reply #1 on: August 01, 2012, 12:35:47 pm »
What size is he running?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Stripped66
« Reply #2 on: August 01, 2012, 15:07:55 pm »
Causes?
Pulleys are actually not aligned well.
Top pulley adjusted so that the belt is ridiculously tight.
Using a 1/2" belt instead of a 3/8" belt.
Pulley surface is gouged with sharp edges.
« Reply #3 on: August 01, 2012, 15:51:27 pm »
i think its a 900 mm gates.
pulley surfaces are new,
10 mm wide
its a 2165 in a bus...
if we loosen the belt, it flips over.
I ll check re-alignment again...
 thanks!
« Reply #4 on: August 01, 2012, 16:24:37 pm »
10 mm wide
 thanks!
What brand bottom pulley? you may find it needs a 9.5 wide belt to keep it on,some pulleys dont have a deep enough of a groove cut in them
« Reply #5 on: August 01, 2012, 19:41:39 pm »
hey Richie,
its a scat sand seal normal size...
Erlend / bug66
Global Moderator
SCC Event
« Reply #6 on: August 01, 2012, 19:53:27 pm »
My engine ate belts as well. It's noe aligned perfect and works well :-)
The '67:
The '59:
Not yet..
