September 22, 2026, 07:09:23 am
| | |-+  Fire up a draw through turbo engine?
Author Topic: Fire up a draw through turbo engine?  (Read 8671 times)
Basti
« on: August 02, 2012, 09:49:22 am »
Hi Guys,
how do you fire up your draw through turbo engines?
My spark plugs are often too wet, and then the egine is not starting anymore ;-(
Thanks,
Basti
- black 62 cal look beetle
- Pro Mod Race car
Tekken
www.proturbovw.com
« Reply #1 on: August 02, 2012, 10:25:30 am »
What type of carb do you use?
Basti
« Reply #2 on: August 02, 2012, 10:56:39 am »
I am using a daemon 850cfm....
Basti
- Pro Mod Race car
RMS Boxer Service
« Reply #3 on: August 02, 2012, 11:07:07 am »
Check that the carb is mounted correct. The demon carb is very sensitive to mounting, it must be level othervise it will flood fuel into the intake.
/Rolf
« Last Edit: August 02, 2012, 21:37:48 pm by Callook_67 » Logged
Martin Greaves
10.88@128.58
« Reply #4 on: August 02, 2012, 20:54:33 pm »
Basti
What size of turbo do you have.
Hotrodvw
« Reply #5 on: August 07, 2012, 02:14:05 am »
1:  That's a Huge Carb.........unless it's 100% drag, a 650 will suffice.
2: Long intake tract.  A quick shot of Ether (Starting Fluid) will help it to fire and get the vacuum going to draw fuel
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
jamiep_jamiep
« Reply #6 on: August 10, 2012, 10:09:50 am »
When I first got mine it used to do this, my problem was I pumped the accelerator pedal while trying to start, and with 50cc acc. pumps it was just soaking everything. Now one or two pumps and hold the throttle steady open until it fires seems to work - I never need any spray or anything.
Mines a 650 DP btw. so not quite the same carb.
dragvw2180
« Reply #7 on: August 10, 2012, 14:03:53 pm »
What do you have for ignition setup ?  Have you setup everything on a dyno or wideband ?  On my PRO OUTLAW car it fires up almost immediately but I am only running a 600 Holley double pumper w/mechanical secondaries. I unhooked the rear accelerator pump as it is not needed. I would NOT  use starting fluid on a regular basis , matter of fact I have never needed it on my race car. I know you probably have a bigger engine ( mine is a 2387 /366 rwhp) that needs that much carb but it shouldn't flood easilly if set up properly. My carb is mounted sideways with the linkage facing toward me when I am standing behind the car. If your ignition system is doing its job , if the timing is set around 25 degrees , if the intake manifold is shaped properly so no low spots can collect fuel, if your secondary accerator is unhooked , if all the stars are in alignment then it should start right up, hahahahah  Mike McCarthy
this is an old pic, I have changed carb since it was taken,
Basti
« Reply #8 on: August 25, 2012, 16:30:12 pm »
It was just the high torque starter...
No problems with a automatic starter!
Thanks to richie for the advice!!
Cheers,
Basti
- Pro Mod Race car
« Reply #9 on: August 25, 2012, 16:46:47 pm »
Cheers,
Basti
Excellent,glad it worked out for you Smiley   will you be ready for Das drag day?
cheers richie
