September 14, 2026, 14:01:58 pm
352306 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  Fuel pumps for methanol
Author Topic: Fuel pumps for methanol  (Read 5521 times)
Andy Sykes
« on: August 05, 2012, 17:37:02 pm »
Hi guys as I'm now going methanol what fuel pump would you recommend for circa 800bhp I've found this little different to an electric pump but I will have a toothed drive any way anybody got any recommendations
http://aeromotiveinc.com/products-page/fuel-systems/universal/17140-belt-drive-pump-kit/
Cheers andy
« Last Edit: August 05, 2012, 22:44:55 pm by fast65 » Logged
Martin
Cash Converter....
« Reply #1 on: August 05, 2012, 20:38:36 pm »
 i used to use that pump, you have plumb in a prime pump to get rail pressure up.
 I now use a Weldon pump. buy the best they make pumps for aircraft. Wink
Martin
Martin
www.taylormachine.co.uk
OFF/500
Andy Sykes
« Reply #2 on: August 05, 2012, 20:49:32 pm »
Ok thanks I did wonder if it got enough pressure turning over which pump are you using Martin
Cheers andy
Martin
Cash Converter....
« Reply #3 on: August 05, 2012, 21:40:59 pm »
mine is the DB2525-A. think you'll find its has one of the lowest current draw of any of the high out put pump.
you also will need to get the filters 40 micron pre filter as the pump has really tight tolerances and a 10 micron post filter to protect the injectors.
Martin
Martin
OFF/500
Andy Sykes
« Reply #4 on: August 05, 2012, 22:03:09 pm »
Ok thanks Smiley
Cheers andy
