July 02, 2026, 07:16:09 am
Latest Member: bigsiembowski
| |-+  For sale!
| | |-+  Anyone interested in 2332 pauter long block SOLD
Author Topic: Anyone interested in 2332 pauter long block SOLD  (Read 4732 times)
bedjo78
« on: August 16, 2012, 01:20:54 am »
My Son studying overseas. no have time to run the spit bug. I  have 2332 longblock that I will offer for sale. the engine has been rebuild and only run on idle. never been on track since rebuilt
spec of the longblock is bellow
compression set 8.2 : 1
Case As 41 germany std bore. 6 ea shuffle pinned. clearanced for 86 stroke.
Crank Bugpack 84 stroke chevy rods wedged
Flywheel. match Lightened german flywheel
Carillo 5.7 in checy rods
fk87 turbo grind ( i have fk 87 std grind, fk89 std grind, pauter turbo cams. 8c turbo grind)
       let me know i will change if you wish
cam follower; Pauter t1 solid
Heads, Pauter Super pro heads 50 x 40 . chamber 55 cc
Rocker, Pauter Super pro rockers 1.6 : 1
Piston / Cylinder  pauter 94mm
Pushrod pauter
some picture
a new cam lifter break  In with IDA's
« Last Edit: October 30, 2012, 10:55:07 am by bedjo78 » Logged
bedjo78
« Reply #1 on: August 16, 2012, 01:31:53 am »
The Car,
pan car with Tube Chasis. 32" ladder bar. coil over shock. close ratio tranny with billet spool. berg shifter. rack pinion etc
Green Goblin
« Reply #2 on: August 16, 2012, 08:02:04 am »
Hi,
I could be interested in the long block.
Do you have a price and location please
Many Thanks
Andy
bedjo78
« Reply #3 on: August 16, 2012, 08:27:19 am »
I am offering $5500 for the longblock + shipping. for a complte engine set up $6500 haltech ECU with MSD dist, MSD AL and MSD coil. and I will adding Jaycee crank trigger base/pulley for free.
piston/cylinder and heads  had very limited run only 5 passes on 1/8.  heads with titanium valves
location Semarang 50193, Indonesia. you could calculate shipping via Fedex economy or UPS. airparcel post office might be too big and too heavy.
Green Goblin
« Reply #4 on: August 16, 2012, 19:47:16 pm »
Many thanks for the response.  Unfortunately the shipping from Indonesia to the UK is too expensive for me.
Thanks Anyway
Andy
bedjo78
« Reply #5 on: August 17, 2012, 05:10:48 am »
Pm me your offer pls.
bedjo78
« Reply #6 on: August 19, 2012, 04:20:16 am »
i am willing Part out the heads and cylinders $2700  Shocked
