September 22, 2026, 21:24:28 pm
| | |-+  Line lock adapters
Author Topic: Line lock adapters  (Read 9053 times)
Stefan Rossi
« on: August 22, 2012, 23:17:44 pm »
Hi, need 3 line lock adapters, don't really fancy paying 12 pounds each from Heritage for some small brass fittings that probably cost about 50p,
Anybody know a good place to get them from in England. Maybe a pipes and fittings place or somewhere?
Or even better where I can get some GM brake unions from to make my own lines?
Stef  Smiley
« Last Edit: August 23, 2012, 00:16:35 am by Stefan Rossi » Logged
Aircooled Engineering. Birmingham, England
www.ace-vw.com
Check us out on FB, www.facebook.com/aircooledengineering
www.dtavw.com
'67 vert
'67 Chevelle PT106mm turbo
'66 Lincoln
Berger
www.bugrent.no
« Reply #1 on: August 23, 2012, 07:46:43 am »
I got mine from Jo and Richie www.rjvolksperformance.com
Payed 30£ including postage to Norway Smiley
This is my simple religion:
-Be cool
-Don't be an asshole
Erlend / bug66
Global Moderator
SCC Event
« Reply #2 on: August 23, 2012, 07:50:12 am »
Does anybody know what size these are in?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
jmarkha1
« Reply #3 on: August 23, 2012, 07:58:36 am »
Mocal in Isleworth Middlesex should be able to help you.
http://www.thinkauto.com/
« Reply #4 on: August 23, 2012, 08:35:10 am »
m10x1 inlet side and 1\8 npt to the linelock
we do have them in stock,but you wont find them anywhere for 50p
cheers richie
Fasterbrit
« Reply #5 on: August 23, 2012, 08:43:49 am »
£3.95 each on eBay  Cool
Look at this on eBay:
1/8 NPT to M10x1mm Brake Hose Fitting Connector Adaptor
http://bit.ly/SpOABL
www.air-kraft.com
www.marcomansiperformance.com
« Reply #6 on: August 23, 2012, 08:50:25 am »
Mat that isnt correct,the m10x1 is a female to take the vw brake line ends
cheers richie
Fasterbrit
« Reply #7 on: August 23, 2012, 09:15:57 am »
Hi Rich. When installing a line lock you would probably need to make custom brake lines anyway, so simply make them with female M10 ends and save a wad of cash Wink
Regards, Matt
Ps. How did you get on at the Scc?
www.air-kraft.com
« Reply #8 on: August 23, 2012, 10:21:15 am »
Regards, Matt
Agreed.
 but it is possible to use stock replacement VW hard lines available from lots of places and the adaptors I use allow this Smiley and for some the cost of the correct flaring tool outweighs any saving on the other adaptors Wink
SCC,not the best,I made too many changes and the rain made it impossible to get enough runs to dial everything back in,but I leant enough to hope next time out will be better,we seem to have cured some of last years problems but only after getting more runs will I be able to tell for sure,the data from a couple of passes isnt enough for me to make judgement
cheers richie
Stefan Rossi
« Reply #9 on: August 23, 2012, 13:18:18 pm »
cheers richie
Hey Richie, just looked on your site again, I will get 3 from you then, I need some other bits too so is it just best to call you or Jo?
Thanks, Stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Russell
« Reply #10 on: August 23, 2012, 14:43:08 pm »
Ive found that using the correct adaptors are the best way and hard piping the line locks in, not sure that Heritage charge £12.00 each for these to be honest.........
Best Regards
Russell
Stefan Rossi
« Reply #11 on: August 23, 2012, 21:52:44 pm »
Adapters and vw lines or do you mean vw one end and GM the other end on the break pipes?
Have a look on their site, they are 11.90 each Shocked
Stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
Jesse/DVK
'64 2176cc
« Reply #12 on: August 23, 2012, 22:01:36 pm »
This Dutch webshop has them for 8,5 eur each.. Still a lot of money..
http://www.hotrod.nl/shop/contents/nl/d264.html
Stefan Rossi
« Reply #13 on: August 29, 2012, 00:57:05 am »
Yeah it is still a lot for what they are. Be good to know how much they cost from whoever makes them because they seem to be the same kind of price everywhere.
Stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
