October 13, 2026, 04:59:26 am
Magnesium wheel repair
Topic: Magnesium wheel repair (Read 17163 times)
2manytoys
August 23, 2012, 23:35:02 pm »
Anyone out there making repairs to Magnesium wheels? I have a D spoke similar to the one in my avatar that needs to be repaired. The wheel is straight, but it has some serious pitting where it looks like it was sitting in mud or water...... The top 3/4 of the wheel is near mint. Check out the center snout,...see the slight taper up. Most mag d spoke wheels I have seen have a flat center cap area. Maybe someone has a singe they want to sell.
It has been a loooooooooooooooooong wait finding one of these wheels, I would like to be able to save it, rather than use it as a spare only where the bottom of the rim is out of view.
thanks,
P-
this is my ad..........
http://www.thesamba.com/vw/classifieds/detail.php?id=1005918
Last Edit: August 23, 2012, 23:38:40 pm by 2manytoys
Re: Magnesium wheel repair
August 24, 2012, 01:09:41 am »
I would say if anyone can, it would be Eric Vaughn.
nlvtinman
August 24, 2012, 01:42:38 am »
I have heard that Eric no longer will machine magnesium wheels. Somehow I think it was due to his having a mag caused fire-has anyone else heard that? I could be wrong.
2manytoys
August 24, 2012, 01:43:09 am »
Quote from: Zach Gomulka on August 24, 2012, 01:09:41 am
I called him today and was out all day. Will try him tomorrow, but I understand from someone else that he does not work on magnesium wheels any more. I will follow up with him again.
But thanks ZG...
P-
2manytoys
August 24, 2012, 01:44:31 am »
Quote from: nlvtinman on August 24, 2012, 01:42:38 am
You tree'd me. And yes I heard that he is no longer doing magnesium wheels because of a fire,...but that is not confrimed from Eric.
Taylor
August 24, 2012, 02:22:20 am »
I heard before that Clyde Berg fixed cracked BRMs, maybe try him?
August 24, 2012, 03:19:13 am »
Quote from: Taylor on August 24, 2012, 02:22:20 am
Sil Modesti will do that also, he's pretty close to me. But as for major corrosion...
Bill Schwimmer
August 24, 2012, 04:09:30 am »
I would try bead blasting it first. I have done this with BRM's & under the fuzz they were pretty decent. Worst case you will need a lathe turn on the lip & a polish. You could contact Sihilling metal polishing in Santa Ana for the polishing & I think Clyde B. could do the machine work if needed. Bill
Eddy Merckx
johnl
August 24, 2012, 04:34:44 am »
Quote from: Bill Schwimmer on August 24, 2012, 04:09:30 am
I would try bead blasting it first. I have done this with BR M's & under the fuzz they were pretty decent. Worst case you will need a lathe turn on the lip & a polish. You could contact Schilling metal polishing in Santa Ana for the polishing & I think Clyde B. could do the machine work if needed. Bill
I highly recommend Schilling as they have done work for me for over 40 years. Charlie Schilling's dad, John did my first two Americans and the work was outstanding. They have done the plating and polishing on most everything on my Chrysler restorations. Sometimes expensive but the bottom line is you get what you pay for. They have always stood by there work and if there was ever a problem made it right with no argument. There phone number is 714 543-7051 and they have been in the same location since the '40's.
henk
August 24, 2012, 11:27:02 am »
here are a few adresses i found from a bike forum i on as well.
the best way to protect magnesium is using zincromate that seals the magnesium complete of from the air.
http://www.framestraightsystem.com/Video.htm
Mackie Welding in Sierra Madre
Close to Pasadena
decades of experience
(626) 355-7058
DR Johns Frame Repair in Orange County California.
henk!!!
2manytoys
August 24, 2012, 18:28:30 pm »
Thanks for the leads,..I will follow up and let you know what I find out.
Any American Magnesium D Spoke wheel experts out there,.....on here? These wheels are actually not "D", but rather GTP wheels I believe, they pre-date the D spoke wheels.
p-
August 24, 2012, 19:07:11 pm »
Its hard to see in picture, Is it just pitting or is the lip of wheel damaged ? If you need to do any welding on lip of wheel, Find somebody with a big lathe! Maybe PIP, He has been doing some outstanding wheel work lately !. Have him or somebody do a cleanup cut on lathe maybe .020-.030 cut Then chemical clean wheel, Do not blast, It will just contaminate mag even more. That is the problem welding, dirty metal is a bitch to boil out when welding . So do a lot of wire brushing with SS brush and a chemical that will remove any corrosion. And if you do any welding, Have a bucket of sand/dirt handy. To dump on mag if she catch's fire! will help knock oxygen out of fire. Hope this helps in some way.
Cornpanzer
August 24, 2012, 22:42:06 pm »
Looks like the first generation D spoke with hollow spoke backs and no strengthening ribs around the perimeter. later generations got ribs running radially in the backs of the spokes and the final generation had small ribs on the sides of the spokes.
Most of these wheels came with the hub like this. I havent figured out if people machined them flat so that they would accept a cap from a Fuchs wheel or if American offered them with the flat hub.
Harvey Weidman at Weidmans wheels iin Orrville Ca can weld mag. Tell him hi when you speak to him.
Last Edit: August 24, 2012, 22:43:55 pm by Cornpanzer
'67 Turbo Sedan
Ultra VW Contributor
2manytoys
August 25, 2012, 04:53:46 am »
Darn it Danny,...it did a little bit of media blasting on it today to see what it looked like(but only a little). The wheel is straight,..very straight, and the top 3/4 is clean...mint clean. There are no cracks or dings on the rim. The pitting on the bottom is the problem. I talked to a couple people about fixing it. One thing is, if it needs welding to fill imperfections, it is best to use magnesium from an old rim as better to match the type of material in the wheel. I have a good buddy here in Nor Cal that can weld magnesium...Dave Bonbright of Engine Masters, he is an artist. I think it can be fixed, it's just a matter of putting in the time. One person suggested if it is just for show, use epoxy to fill any pitting, sand it and paint the center. I have other people say don't bother, the old mag is too dagerous to run a car on......... I like them. The wheels look awesome. They are really works of art, and the fact that these are super early, I want to see if I can save it. I am not sure if some of the early wheels had the snout cut off flat to accept a porsche cap, but I am not going to cut these.
I have talked to a couple of people (thanks Henk) about the rim repair, and believe it or not, I may have some luck. I will be checking runout on one rim and cleaning more with wire wheels (Thanks Danny) to see how bad or good the rim is.
thanks,
P-
John Palmer
August 25, 2012, 05:46:45 am »
Quote from: henk on August 24, 2012, 11:27:02 am
Close to Pasadena
(626) 355-7058
henk!!!
I have used Dr. John's as an outside vendor to our dealership on motorcycle crash repairs for many years. They do all kinds of frame and wheel alignment and repair work. They are a very knowledable shop and have the years of "hands on" experience to look at something and give you true expert advice and service. They are located just north of La Palma between Tustin and Kramer.
August 25, 2012, 16:03:24 pm »
I would try to stay away from doing any welding on that wheel, If you can! Might open a can of worms. Maybe try a light cut on the lathe on wheel lip. And try sanding deep pits out by hand. Start with rubber pad and maybe 36 grit and work down on grit, on spokes. Just a Idea.
Bill Schwimmer
August 25, 2012, 21:48:54 pm »
I have bead blasted lots of magnesium wheels & polished them & they turned out nice, never had them welded on however....I did a set of BRM's for Russell a couple of years ago that looked like that. I thought they were going to be nasty under the fuzz, but it came off & they were pretty decent underneath. I think a light lathe cut is in your future to make the pits shallower & a polish to flow them out..
Eddy Merckx
2manytoys
August 28, 2012, 04:56:31 am »
I talked to Jim, I think his name was Jim, at Dr. Johns in SoCal. Nice guy and they do work on Mag wheels. I explained the situation and they may be able to help. I actually have two wheels that need some help, the wheel with the pits,...there is no way to remove the pits with sanding,..no way not how. Well, there is, but I would remove way too much wheel. The other rim was curb shot pretty hard on the inside I would say by the looks of the damage. If I can get Dr. John to make the bent wheel straighter, I could use the pitted wheel for a spare.....or sell it once it is cleaned up.
I never realized how hard it is to find this style mag wheel. The flat snout later version are like noses..everyone has one. The taper snout on the early wheel, forget it!
Quote from: Cornpanzer on August 24, 2012, 22:42:06 pm
....anyway you could post some pics if you have any? I want to compare the different wheels I have, early and late mag and aluminum,....
P-
