July 10, 2026, 03:19:51 am
JennyW135
36hp Mods
Topic: 36hp Mods (Read 70591 times)
Re: 36hp Mods
Reply #30 on:
September 17, 2013, 00:53:41 am »
Gday Richard.
Cool stand!
My 2c for the high idle is probably either too much fuel/air mix, which means even though the screws are shut off they may also need idle feed restrictions (just a guess based on V8 Holley/Carter stuff though, never had twin singles on an ACVW, sorry), or else a manifold vacuum leak somewhere. Have you checked the carbs for small vacuum hose connections that aren't plugged up? Crossover connections on the runner stacks that have cracks?
Cool looking old Dak-Dak man!
RichardinNZ
Re: 36hp Mods
Reply #31 on:
September 17, 2013, 01:43:50 am »
Modnrod; thanks for the thoughts. Need to double check for air leaks again.
regards
Richard
Last Edit: September 17, 2013, 01:46:57 am by RichardinNZ
'58 Bug; NZ assembled
Dual Carb 36hp
hotrodsurplus
Re: 36hp Mods
Reply #32 on:
September 18, 2013, 02:55:46 am »
Idle-feed restrictor is caveman speak for idle-fuel jets. They govern the part-throttle fuel curve.
Are the throttle shafts tight in the bore? One slightly leaky shaft may not leak enough air to affect the idle speed but two leaky shafts will.
Also, just because a carburetor throttle-shaft bore has been rebushed doesn't mean that the carburetor will work properly. When the throttle-shaft bore wears the harder brass butterfly will gouge a nice trough in the throttle bore. Even though I had Rimco re-bush the 34PICT3 for another car I couldn't figure out why I couldn't set a really slow idle until I started working with Solex PII carburetors. Those suffer it terribly.
just a thought....
RichardinNZ
Re: 36hp Mods
Reply #33 on:
September 19, 2013, 22:08:30 pm »
Thanks for the additional thoughts. I'll have a closer look at the carbs although did initially think that they were ok.
Hope to post a movie of it running soon too.
Richard
Dual Carb 36hp
Re: 36hp Mods
Reply #34 on:
September 19, 2013, 23:53:06 pm »
Check for air leaks with carb cleaner. Spray it at the base of the manifolds and the base of the carbs and around the outside of the carb. Do this while the engine is running and if the speed changes dramatically then you have found the leak. Old school...
hotrodsurplus
Re: 36hp Mods
Reply #35 on:
September 20, 2013, 05:33:20 am »
Quote from: Donny B. on September 19, 2013, 23:53:06 pm
It works but it's never been foolproof for me. I've had examples where carb cleaner didn't reveal leaks, especially ones behind a maze of parts. And because I'm a tight ass and rattle can my tins the carb cleaner sometimes eats up the finish. Also some modern carb cleaners aren't flammable.
Here's another old-school way. Get a foot-long piece of fuel hose with an ID about the same diameter as the OD of a propane torch tube (sometimes you have to remove the mixer). Turn on the torch and waft the hose end over the suspect areas. It's never let me down. Plus it won't mess up your finish. And last I checked they haven't changed propane to a non-flammable formula. At least not yet. Give them time.
But definitely try the carb cleaner first if it won't mess up your tin finish. Way more convenient.
RichardinNZ
Re: 36hp Mods
Reply #36 on:
September 25, 2013, 10:01:34 am »
Used the carb cleaner and did get a drop in speed; mainly around the spindles so rebuilds will be needed sometime. Will just put up with it for now though so I can enjoy the car over the summer.
Thanks for the assistance.
Richard
Dual Carb 36hp
hotrodsurplus
Re: 36hp Mods
Reply #37 on:
September 25, 2013, 16:31:55 pm »
Quote from: RichardinNZ on September 25, 2013, 10:01:34 am
Sorry bud but they're beyond just rebuilding. They need to be bushed. It's not the end of the world but it's not exactly a common procedure anymore. Don't bother bushing them if you can feel even a faint line where the butterflies meet the throttle bores. That indicates that the butterflies have dug in and you'll never get a good idle if that's the case. They need to be bored at that point and that's a super-involved operation compared to bushing them.
RichardinNZ
Re: 36hp Mods
Reply #38 on:
October 08, 2013, 09:08:55 am »
Sorry for delayed reply...packing ready to move houses (and before that trying to find a house...all sorted now with a good garage and car port!). Will pull the carbs in the winter and check them over some more in light of your advice. For now will enjoy driving the car and our show season!
Richard
Dual Carb 36hp
RichardinNZ
Re: 36hp Mods
Reply #39 on:
December 10, 2015, 20:31:25 pm »
Update on my car...
Finally back on the road again having destroyed a clutch release bearing in Oct'14...now with rebuilt tunnel trans (with superdiff etc ready for a stroker engine one day...), new Koni shocks all round, Goodridge Classic Brake Hoses, Type 3 rear brakes and a 14" Berg Shifter.
Great to be driving again...
Next step will be to get the rear wheels widened (I'm thinking 5 inch with increased back space allowable by fitting the Type 3 drums), and 185/80 tyres on the rear and 155/80 on the front....along with a minor decamber on the rear to move from the current positive camber....probably early in 2016.
Richard
Dual Carb 36hp
RichardinNZ
Wheel bolts....!
Reply #40 on:
June 09, 2016, 00:21:38 am »
Ok...finally got some wheels widened. But as usual one step forward and two steps back.
Took off the existing rear wheel to check the fit of the new wheel (5 1/2 inch rims added to original centres with maximum backspace to hide the fact that they are widened when looking from the side). All seems OK. However, when refitting the original wheel I've managed to somehow strip the thread for one bolt. Didn't do anything different to what I had always done, but think it must just be the quality of the Type3 drums I've fitted?
I'm assuming the best option is to fit studs? Does anyone know of a 'how to' anywhere for this? Are these the studs I need?
http://www.socalautoparts.com/product_info.php/aftermarket-wheel-stud-m14-50mm-press-style-porsche-p-15136
. I'm assuming that given the potential 'softness' of the drums the press in studs would be better than screw in studs?
The widened wheel in case anyone wants to see....
Richard
Last Edit: June 09, 2016, 09:50:29 am by RichardinNZ
Dual Carb 36hp
andrewlandon67
Re: 36hp Mods
Reply #41 on:
June 10, 2016, 05:25:08 am »
Man, your wheel setup is almost identical to what I'm looking at for my '67, but with smoothies instead of the goofy '66/'67 wheels... I was considering doing mine to 5 inches up front and 5.5 in the rear, but absolutely nobody in Denver wants to widen steel wheels unless almost all of the work is done for them, so the 5 inchers I found at a swap meet will have to do for the rears... Glad to see someone else wanting to do steelies on a looker, I thought I might be the only one!
14.877 @ 88.85 mph
He who waves at 911 drivers
RichardinNZ
Re:
Reply #42 on:
June 23, 2016, 09:25:20 am »
I will soon be in LA and it'd be a good opportunity to buy a gift for the '58. Would my setup benefit from ratio rockers (to save people reading the whole thread the engine is stock 36hp bottom end, cam etc but large intake valves in Stock 36hp single port heads,compression now 7.5:1, dual 28pci carbs, stock exhaust and TDE big bore tail pipes).
Sent from my SM-N920I using Tapatalk
Dual Carb 36hp
Re: 36hp Mods
Reply #43 on:
June 23, 2016, 15:55:47 pm »
They might help, especially if you give it a little port work.
Re: 36hp Mods
Reply #44 on:
June 23, 2016, 18:03:02 pm »
If you can get some grab them, they seem to be hard to get and if you don't need them straight away then you will as the tuning progresses
RichardinNZ
Re: 36hp Mods
Reply #45 on:
June 24, 2016, 00:46:02 am »
Thanks for the help.
Yes, thinking of exploring the power of 36hp a little further before upgrading to something much larger... Add rockers and an exhaust (I've been told there will soon be a quiet Sebring style available for 36hp)?
However, if I can manage to find them, the Speedwell rockers are available in 1.25:1 and 1.4:1. I'm guessing I'd go for the lower ratio? Also, I was assuming that this was just a bolt on job, but as my heads are skimmed (2mm) and compression increased could I possibly have an issue with valve/piston clearance?
Richard
Dual Carb 36hp
Re: 36hp Mods
Reply #46 on:
June 24, 2016, 06:31:16 am »
The 1.4/1 definitely cause other problems, the lifter/pushrod cant change angle like a conventional VW and the 1.4s work through more of an arc so need to be able to, not sure how bad it is with 1.25s
RichardinNZ
Re:
Reply #47 on:
June 24, 2016, 08:08:13 am »
Thanks for that. I'll see what I can find out about the 1.25s.
Dual Carb 36hp
RichardinNZ
Re:
Reply #48 on:
June 25, 2016, 23:59:40 pm »
Found some 1.4s. I'm told by a 36hp specialist that they will be OK with stock lifters/pushrods and also with my flycut heads. However, if there is a problem with the lifters etc I will move to 'conventional' 2 piece setup. Have also sourced some aluminum valve covers to give the clearance needed. With the obligatory t-shirts etc from the trip I think my suitcase is now full up!
Dual Carb 36hp
JeeWee
the Netherlands
Re: 36hp Mods
Reply #49 on:
July 11, 2016, 11:43:53 am »
cool, good work, I also run a dual carb 36hp, but then with the WW okrasa heads, and modified my stock exhaust with TDE tail pipes and I also removed the preheat pipes, just cut out the preheat pipe and welded a piece of metal in, this improves the flow as well. Make sure you run a Original VW muffler, see also a thread about this on the samba, as original exhaust do have a better flow then some repro's.
RichardinNZ
Re: 36hp Mods
Reply #50 on:
July 12, 2016, 01:56:57 am »
Good point about the original VW exhaust; however mine is a repro! I'm still aiming for a Sebring style sometime later this year!
Dual Carb 36hp
JeeWee
the Netherlands
Re: 36hp Mods
Reply #51 on:
July 12, 2016, 10:40:37 am »
yesterday I spend about an hour to find that topic about the original exhaust on the samba for you to post the link, but I didn't succeed to find it. the issue is that some aftermarket mufflers have baffles in the exhaust which has quite some impact on the flow. It is a cheaper way to produce so that's why.
But when you remove the preheat pipe you will get some more flow as well! Original VW exhaust can be found around 200 euro's, so it is cheaper then a flat 4 or whatever vintage speed exhaust, and doubt the improvement, so if you are on a budget this might be the best way to go. Also Original VW exhaust has more or less equal pipe length.
RichardinNZ
Re: 36hp Mods
Reply #52 on:
September 15, 2016, 22:05:38 pm »
Vintage Speed now list a Sebring style exhaust for 36hp engines; see
http://shop.vintagespeed.com.tw/s.nl/it.A/id.872/.f
I've checked with them and this is manufactured with 38mm pipes. My 36hp is only mildly tuned (to recap; stock single port heads flycut for 7.5:1 compression, 33mm intake valves, dual 28PCI carbs, stock bottom end, soon to be fitted 1.4:1 ratio rockers, VJU4BR8 distributor with same curve as 019 or Resolit distributor reputedly same curve as 010).
How well suited to my setup do people this this exhaust might be; are the pipes too large for my engine?
Many thanks
Richard
Dual Carb 36hp
RichardinNZ
Re:
Reply #53 on:
September 21, 2016, 20:44:25 pm »
Anyone able to help with this? Thanks.
Dual Carb 36hp
RichardinNZ
Re: 36hp Mods
Reply #54 on:
January 21, 2017, 07:49:22 am »
Photographed today; now with rebuilt 28PCI carbs, 1.4:1 ratio rockers, vintage speed sebring exhaust and 205/70x15 tyres on the rear ( mounted on widened 5.5 inch stock wheels). Needs a good clean and eventually some bodywork....
Dual Carb 36hp
RichardinNZ
Re: 36hp Mods
Reply #55 on:
March 31, 2019, 19:51:46 pm »
Still making minor changes and improvements and driving as much as I can.
https://youtu.be/tGjPWgpS-3M
Sent from my CLT-L09 using Tapatalk
Dual Carb 36hp
RichardinNZ
Re: 36hp Mods
Reply #56 on:
September 14, 2019, 21:54:06 pm »
I've been perfecting the stance over the past couple of weeks after fitting 145/80R15 Michelin XZX on the front (205/70R15 on the rear) . Also fitted EMPI wide5 disc brakes on the front (which despite all the criticisms of EMPI fitted without a hitch).
Dual Carb 36hp
andrewlandon67
Re: 36hp Mods
Reply #57 on:
September 14, 2019, 22:48:41 pm »
Quote from: RichardinNZ on September 14, 2019, 21:54:06 pm
Richard, that thing's looking hard as all get-out! I really like the wheels, they really set the whole car off!
14.877 @ 88.85 mph
RichardinNZ
Re: 36hp Mods
Reply #58 on:
September 14, 2019, 23:21:18 pm »
Thanks! Wheels were decided by my budget but I'm really pleased with them. Stock front (4 inch) and 5.5inch rims on stock centres rear. The trim rings help but most important the tyre choice.
They look better on the rear where I have studs. Looking to fit studs on the front too.
Dual Carb 36hp
Vdubchef
Re: 36hp Mods
Reply #59 on:
October 07, 2019, 09:29:25 am »
Quote from: RichardinNZ on November 23, 2012, 00:42:09 am
Nearly finished...
Where did you find those velocity stacks for 28 pci carbs? Have a similar set up on my -65 bug.
