October 25, 2026, 10:11:52 am
352327 Posts in 28959 Topics by 6929 Members
Latest Member: Hanibal1
|-+  Happenings
| |-+  Happenings
| | |-+  JPM Dynoday #9, 6th of October.
Pages: 1 [2] Print
Author Topic: JPM Dynoday #9, 6th of October.  (Read 39071 times)
Bad bug
« Reply #30 on: November 14, 2012, 02:16:02 am »
Richie i would if i had the money to buy the think, but what i am looking at is for all the engines that are out there with this aluminium block someone must have had the idea to find out why the damn thing runs hot. The type4 engine didn't have this problem so what gives.
« Reply #31 on: November 14, 2012, 03:39:00 am »
none of us have the money to spend on R&D, for most its just trial and error and learn from our mistakes, you will learn lots that way Shocked
I will start you off will a couple of ideas,
They are much thicker in most areas of the case surface and much denser material than the mag cases,typically they weigh over twice as much as the mag case
cheers richie
« Reply #32 on: November 14, 2012, 09:01:56 am »
What does "run hotter" mean? Do you mean you see a higher oil temp, or do the IR temp read the case as hotter, or both?
And do they run hotter as drysump also?
Bad bug
« Reply #33 on: November 15, 2012, 01:18:30 am »
JHU it's the oil i was getting at. All the guys in the states that have built with these case say the oil temp goes up 20 degrees.
Pages: 1 [2] Print
