November 02, 2026, 22:18:47 pm
| | |-+  How big?
Author Topic: How big?  (Read 10942 times)
Andy Sykes
« on: September 08, 2012, 08:51:08 am »
So talking to Russ Fellows yesterday it seams the my 366 bullseye turbo is too small for the Pauter engine I have coming  Cry so I need another turbo it's going to be 2.9l 9:1 comp ratio with modular cylinders on meth. So what turbo would you guys go for and what size headers?
Cheers andy
Fasterbrit
« Reply #1 on: September 08, 2012, 10:27:26 am »
How much hp are you planning to run? I have a Holset HX52 capable of 850-900 sustained horsepower. A lot of the Jap boys run them and make astronomical power  Shocked
It has a billet compressor wheel etc etc.
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #2 on: September 08, 2012, 11:11:15 am »
Hi Matt,
Motor is being built for 800bhp not that I'm going to use that for a while. The s366 is maxed out at 800, so I understand on a flat 4 that's not going to happen due to being inefficent. Russ suggested a S380 he is running a S372 and getting 780bhp and over 700nm torque. Is the HX52 maxed at 900 ?
Cheers andy
Fasterbrit
« Reply #3 on: September 08, 2012, 11:17:12 am »
Yeah, 900 is the limit. Still more than enough for a while Wink
www.air-kraft.com
Andy Sykes
« Reply #4 on: September 08, 2012, 11:20:43 am »
Lol too right it's enough so it should make 750 ish on a flat 4?
Fasterbrit
« Reply #5 on: September 08, 2012, 11:26:30 am »
My HX40 made 638 at only 28psi. The 52 will breeze 750 on a flat four. These turbos are designed to run 45 psi all day long on an artic Smiley
www.air-kraft.com
Speed-demon
« Reply #6 on: September 10, 2012, 08:03:15 am »
Call Tor Øyvind Skinne. He will spec a mean turbo for you  Grin
BR
Jens Kristian
Airspeed
« Reply #7 on: September 10, 2012, 22:07:25 pm »
Andy,
If you want an 80mm turbo for drag racing use, look at this one:
http://www.full-race.com/store/turbos/borgwarner-airwerks/borgwarner-s400sx-80mm-1-25-a-r-t4-turbo.html
With this you can probably retain (much of your) current header routing as its also T4 twin-scroll and I wouldn't go larger on the exhaust diameter if it were me. Just match it nicely to the heads.
I would stay away from Precision (based) turbo's as I've heard and seen too many fail especially in the larger frames..
Walter
« Last Edit: September 10, 2012, 22:11:49 pm by Airspeed » Logged
« Reply #8 on: September 11, 2012, 07:27:29 am »
Whatever turbo you decide to buy make sure you buy it from a place where you get good service, fast handling and cheap shipping, all of which is getting rarer and rarer these days. I know that http://www.turbosdirect.com/ is the choice for some of the world fastest VW. I have also heard that their customer care is top notch. I cant think of nothing worse than being stuck in the garage due to waiting for parts.
-BB-
Andy Sykes
« Reply #9 on: September 11, 2012, 20:19:41 pm »
Thanks very much for your replies looks like I will be buying Matts HX52, I think I can still use my header that's set up for twin scroll ( need to do a bit more research). I'm sure you will set me straight lol. Waste gate a are twin 38mm from what I've read that will be too big  what do you think?
Cheers andy
Shag55
Shag Leone, SL-1racing
« Reply #10 on: September 17, 2012, 19:22:52 pm »
A single TS-44  will be plenty big enough for that motor and turbo. No need for the headach of twins just Y them together.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
Andy Sykes
« Reply #11 on: September 17, 2012, 19:36:40 pm »
Ok cheers bit late it's done lol
So looks like fun setting up two
Cheers andy
JJ Cool L Racing
« Reply #12 on: September 18, 2012, 06:26:37 am »
http://www.kkdmotorsport.com/kauppa.php?k=1270835105
http://www.kkdmotorsport.com/yhteystiedot.php
