October 13, 2026, 21:29:55 pm
Motor plates
Topic: Motor plates (Read 6204 times)
Andy Sykes
Motor plates
September 15, 2012, 19:25:03 pm »
Hi guys anybody got a clue what grade aluminium I should use for a motor plate ?
Cheers andy
Red Rooster
Re: Motor plates
September 16, 2012, 16:32:49 pm »
6082T6.
If you have any problem sourcing it give me a shout. we can supply it to required size or as a fully cut motor plate.
cheers
David
StrokerMcDell
Re: Motor plates
September 17, 2012, 09:17:23 am »
How thick are they
Do you need to extend the input shaft for an ally motor plate
ACE 116
10.67 @ 123mph York 2010
10.89 @ 125mph York 2009
Momentum 99octane pump gas
Red Rooster
Re: Motor plates
September 17, 2012, 09:51:44 am »
Everything we have ever made is 1/4 of an inch thick as per rules.they where for v8's not V8's but the thickness is the same.
The input shaft should be fine. there are bits to be gained by modifying the bellhowsing if not.
David
dragvw2180
Re: Motor plates
September 25, 2012, 04:04:46 am »
Might want to think about the starter gear engagement to the flywheel also , whatever thickness is sandwiched between the engine and transmission will move the ring gear causing the starter to not engage. Mike McCarthy
Andy Sykes
Re: Motor plates
September 25, 2012, 07:07:10 am »
im ok for my aplication a pauter are machining the block to suite
