August 12, 2026, 16:34:26 pm
40idf jetting on 69x88 motor
Topic: 40idf jetting on 69x88 motor (Read 6806 times)
axam48ida
June 23, 2007, 05:45:56 am »
any suggestions on jetting of a small displacement motor with 40 idf's
motor has a very mild cam, lightly ported heads
It's not popping or coughing....just lags on low end from intial start
I have F7 emulsion tubes, 115 mains, 160 air and 45 idle
mid range and top end seem fine
Rasser
Re: 40idf jetting on 69x88 motor
June 23, 2007, 11:41:43 am »
Your vents plays a big role in jetting... what size are you running ?
1955 type1
1966 type2 13w deluxe
axam48ida
June 23, 2007, 18:53:54 pm »
28 vents
alex d
June 23, 2007, 21:28:51 pm »
I'd try larger idles
June 24, 2007, 16:13:06 pm »
i run 28 vents in my 1641
and i have 115 or 120 mains
and 190 air
and idle jets are 50 if i am correct.
not sure at the moment what tubes i have...
Rasser
June 24, 2007, 18:05:11 pm »
Sounds like you´re sizes aren´t completely wrong.
But i too would try 50 idles or 55, and adjust the floatheight and acceleratorpump.
How about synchronization - is it spot on ?
1955 type1
