August 13, 2026, 00:07:49 am
| |-+  For sale!
| | |-+  parts for Sale.can bring to EBI
Author Topic: parts for Sale.can bring to EBI  (Read 3975 times)
« on: June 23, 2007, 09:52:34 am »
Ok got this lot for sale.can bring any of it to EBI
94mm mahle stroker bareells& pistons£160
68 on Beetle Scat shifter£70
bay window Scat shifter£85
90.5 mahle barrells& pistons,new£140
90.5& 94mm copper head shims 0.040& 0.060 available£25
90.5& 94mm barrell shims,various thicknesses,to use when you use longer than 69mm stroke£18
1.4 ratio rockers£110
1.25 ratio rockers £110
Scat 1.25 or1.4 ratio rockers £175
8 dowelled lightened chromoly forged flywheel£90
Kennedy stage 1& stage 2 clutch covers£90each
Solid clutch disc[standard material unsprung]£18
scat I beam rods,3/8 bolts,5.4length £100
Scat h beam rods 3/8 bolts 5.4 £175
scat chromoly gland nut& washer£16
Scat stainless valve covers£20
Shadeck 26mm oil pump£23[plugged for full flow+£5]30mm also available
8mm chromoly head stud kit£42
10mm chromoly head stud kit£45
manton cut to lenght push rods£38
straight cut cam gears,adjustable£70
deep sump£50
Santana style pulleys,with black or blue degree ring£28each
engle FK42,FK44,Fk8,FK87& FK89 cams,stroker clearanced £70each
75gram lightweight lifters £60
1 1/2, 1 5/8, 1 3/4 Scat merged headers for sale,all new,
the 1 5/8 is ceramic coated and is £150
1 1/2 in raw metal £90
1 3/4 in raw metal £130
cheers richie,uk
« Reply #1 on: June 25, 2007, 21:22:09 pm »
94mm stroker barrells & pistons sold thanks,richie,uk
« Reply #2 on: July 11, 2007, 20:49:16 pm »
Hi Richie, what are my paying options if i would order some of these parts from you,
Cheers,
Harry/The Netherlands
« Reply #3 on: July 14, 2007, 11:11:40 am »
hi Harry,can do paypal,money transfer,cash etc cheers richie,uk
