October 14, 2026, 01:13:15 am
| | |-+  ignition probleme???
Author Topic: ignition probleme???  (Read 4530 times)
henk
« on: October 01, 2012, 16:03:17 pm »
hallo,
i recently have a probleme with my engine.
it starts good but when i drive it it stops running very soon,today after 3km and yesterday even after 100 meter Sad
it is really sudden like you turn of the ignition key.
so i don't think it is the feul pump,but i will check it anyway.
i gues more it is the ignition,i have a MSD systeme on it.
-MSD 6T
-soft touch rev controle
-distributor
-Blaster High Vibration Coil
so i want to try to find out what is not working:
-is there a way to override the MSD 6T box?
-can i change the MSD coil with a stock?
or any other thought on this please.
henk!!!
henk
« Reply #1 on: October 02, 2012, 09:10:29 am »
nobody who has an idea on this?
yesterday after it shut down again,we did that test with the white wire that you have to ground.
if ground that wire the spark plug only sparks one time.
and if i have done this the engine starts again.
it is like the MSD box reset or something.
but the probleme stays there some time later the engine shut off again.
henk!!!
wolfswest
« Reply #2 on: October 02, 2012, 10:56:35 am »
Hi Henk,
don't know where you live in Belgium but my engine is in pieces for the moment so you can use some parts from me to find the part that's failing.
I have a complete 009 with compufire and coil, a msd coil, a msd distributor, the 6T box is harder because that's build in.
Let me know if you want to borrow something,
Dem
henk
« Reply #3 on: October 02, 2012, 21:47:55 pm »
hallo,
that would be great.
sent you a PM.
henk!!!
henk
« Reply #4 on: October 03, 2012, 21:54:28 pm »
today i tested the box like on the MSD site.
but when i ground the box whit the white wire nothing happens,no buzzing noise or spark.
when i short the green and purple wire whit a paper clip i hav ea good spark on the lead that goes from the box to the distibutor.
if something goes wrong with the box is then mostly all or nothing or good it be that there is a bad connection inside so it falls out sometimes?
or does this look more on a bad coil?
henk!!!
